Okay everybody, I need a little help from you.
What is the biggest EV charging circuit that could be installed in your house? This sounds like an easy question, but it turns out not to be. The answer depends on a lot of factors, all spelled out in the National Electrical Code (NEC).
Now those of you who are familiar with the NEC, or other such regulatory language, know that the answer is never simple. Our guy in charge of installations is (Vice President of Customer Service and Support) Mike Harrigan, and his people have asked about 10 qualified electricians for a definitive way to answer this question and got about 10 different answers. This is not helpful…
So I did what I usually do in such circumstances – I pulled out the book and read it. In this case, I pulled out the 2005 NEC, found the relevant section (Section 220) and read it over and over about 20 times.
Yuck. It is full of language like this:
“For ranges individually rated more than 8¾ kW and of different ratings, but none exceeding 27 kW, an average value of rating shall be calculated by adding together the ratings of all ranges to obtain the total connected load (using 12 kW for any range less than 12 kW) and dividing by the total number of ranges. Then the maximum demand in Column C shall be increased by 5 percent for each kilowatt or major fraction thereof by which the average value exceeds 12 kW.”
As it turns out, there are two applicable paths through Section 220. The easy one is Subsection IV, Optional Feeder and Service Load Calculations. This section provides a quick and dirty method for determining the available ampacity for an existing house when you are doing a structural addition or adding more electrical circuits. This is the way an electrician will quickly tell whether or not she or he can add additional circuits to your house. The trouble is that the calculations from section IV are extremely conservative, and they would lead you to conclude that a major service upgrade is required when it is, in fact, not.
The better path through Section 220 is through Subsection III, Feeder and Service Load Calculations, which also references subsection II, as well as several other NEC sections. This path requires a lot more knowledge about what sorts of electrical devices are connected to your home. It also requires much more math – and the math is different for different classes of electrical loads. It’s pretty hairy, but it is also a lot more precise. No wonder we did not get consistent answers from our electrician experts!
Okay, so this “Column C” in the quotation above can be encoded in an Excel spreadsheet. The goofy math in this paragraph is also the sort of thing Excel excels at, so to speak. So is all the rest of Section 220, if you take the time to read and understand every tangled paragraph.
Anyway, I constructed an Excel-based calculator that does all the hairy math as specified in NEC Section 220, subsection III, and that calculates exactly how much available capacity your electric service has, according to the Code. Click here to open the spreadsheet. (Note: You will need a copy of Microsoft’s Excel or a compatible spreadsheet application to open this document.)
Here’s the help I want from you: For those of you who can run Excel on your computer, please run my spreadsheet. Here is what you will need to do:
- Step 1: Fill in the size of your house in square feet – don’t count the garage or any non-living space such as basements. Estimate a bit high if you are not quite sure.
- Step 2: Look at your main electrical circuits and all your subpanels, and count all the circuits of each type in the spreadsheet. If you have a circuit powering something I don’t specifically ask for (such as a sauna) then put it in the appropriate “other circuits” category.
- Step 3: The spreadsheet will create a line item for each appliance you counted in Step 2. (The column labeled “Load Name” is for your convenience – a place to say something like “basement refrigerator.”) You need to fill in the power requirements for each appliance listed. The best is if you can find the appliance’s nameplate and fill in one of the possible ways it may be listed – either Watts (W), Power (VA), or Amperage (A). Some devices like motors may also list Horsepower (hp). I only need one of these… If you are unable to find the nameplate on the appliance, try the owner’s manual, if you still have it. If not, try to Google the appliance and see if you can find its specs on the web. If none of these works, take a guess.
The way I recommend guessing is to use 80 percent of the rating of that appliance’s circuit breaker.
If you filled everything in correctly, the spreadsheet will report two numbers in the upper-left-hand corner: the required ampacity for the electrical gear in your house, and the available ampacity for things like a spiffy new electric car.
Here’s a few tips:
- Your “main” service amperage will be the rating of your main circuit breaker or fuse, which will be located close to your electric meter. It should be labeled MAIN, but it might not be labeled at all. Sometimes the MAIN breaker is the top breaker in your main panel – the one that is not in line with all the rest – like this one. Other times the MAIN breaker or fuse is in its own box right next to your meter.
- Some houses have more than one “MAIN” service, with two to four breakers right by the meter, like this. In this situation, you will need to consider each circuit separately – perhaps too complicated for this exercise.
- Any breaker in your panel that looks like two breakers tied together with a bar across its levers is actually a 240-volt breaker, and counts as just one 240-volt circuit. There are five such breakers in this picture. Sometimes a 240-volt breaker is double wide, but has only one handle, like the top two breakers in this panel.
Don’t forget to look at any and all subpanels in your house. I don’t care about the breakers in your main panel that feed the subpanels – only the loads within the subpanels that serve appliances or other loads.
Here is what I want from you:
- Tell me (by posting on this blog) what the results are – your available ampacity and the required ampacity for your house as it is now
- Report (by posting on this blog) any bugs you find with my spreadsheet. Please be a little tolerant – you can only do so much with the user interface using Excel!
- Any of you who feel confident about understanding the NEC and who are reasonably comfortable with Excel should unlock the spreadsheet, unhide the hidden columns, and check my math. I give you hints about why I use each formula – pointers to the relevant paragraph of the NEC. Please let me know if I have misinterpreted anything!
The purpose of this particular exercise is only to understand the maximum charging amperage available at your house, as allowed by Code. At this point I am not interested in what your electrical service could actually support.
Note, by the way, NEC paragraph 220.60, Noncoincident Loads:
“When it is unlikely that two or more noncoincident loads will be in use simultaneously, it shall be permissible to use only the largest load(s) that will be used at one time for calculating the total load of a feeder or service.”
This cool loophole would allow more load on your electric service under the right circumstances. For example, one could reasonably argue that you won’t use your oven, cooktop, microwave, garbage disposal, sauna, etc., between the hours of 11:00 pm and 5:00 am. If your electric car was set up to charge at night, then you probably have the available capacity in your electric service even if my Excel calculator says you don’t. If the results of this informal survey show that capacity is a problem for many people, I will consider some sort of mechanism for insuring nighttime charging for houses where this is necessary.
Help me out here: Download the spreadsheet, roll up your sleeves, survey your own electrical service, and report back to me. If you are really inspired, do a few more houses – your parents, your brother, your neighbor, whatever.
Thanks!
Martin
Editor’s note: As Martin gets feedback on the spreadsheet, he will be making adjustments and posting new versions on the blog. The latest is version 1.3. (The version number is located at the bottom left corner of the spreadsheet.)
Posted in the categories: Company, Energy Efficiency
In Canada most homes have a 200 amp electric circuit with 120 and 240. In Toronto electric power is usually maxed out on hot summer days and the “power authorities” suggest to raise the temperature of A/C to conserve electricity.
Electric cars in Toronto ideally would be charged in the evening or during the night, since many utilities also take into consideration the time that the electric power is used. Charging an electric car in the middle of the afternoon during the summer would be more expensive and less socially responsible than charging the car at night.
Tesla should mention how much power the charger will use and for how long it needs to be used to charge the battery pack, this would give a customer the ability to calculate what it would cost to charge the car.
Well, I can tell you that I have a time-of-use meter hooked up to the fancy charger that came with my wife’s Rav4 Electric. Does that help?
So far it looks like only 25amps available at my place.
But that takes into account an existing 32amp avcon circuit for charging the RangerEV, so I think I would need to trade it in on the roadster :^)
Editor’s comment: Thanks for the update, TEG. Martin is looking for both the “required” number and the “available” number. Once you complete the spreadsheet, they are available in the “results box,” in the top left corner of the spreadsheet.
Unfortunately this has nothing to do with the origional blog post, but is more an idea I had that someone who thought up an electric car, as Mr. Eberhard did, would appreciate and consider. Since I could not find an email address for you Mr. Eberhard, I decided to post in your blog.
Dear Mr. Eberhard,
I am writing you this short blip as an idea to put your technologies to further use. I am not sure how you or someone you sold the technology to would do it, but I would be VERY interested in seeing your technology put into a boat. The scenerio, my family owns a cabin in Minnesota and we have an open bow 17′ boat that we ski and tube behind. Every weekend we go up there an duse the thing all weekend, we are spending well over $100 a weekend on gas for it. Boats like ours for pleasure and watersports are TERRIBLE on consumption of gasoline. Ours only has a 140 hp 4-cylinder engine in it, and since you built a sports car that uses a 240 hp electric motor in it, my thought is why can’t you do the same for a boat. It would actualyl be better for an inboard/outboard application to since the motor would not have to be spinning when you are engaging forward and reverse thrust thus lowering the wear and tear on the lower unit that houses the gears making forard and reverse possible.
Now as for chargin the boat, you could have the charging base station up on land and then have a waterproof cable run along a dok to where you normally park the boat. Put the battery pack in the bottom of the boat and spread it out some and then waterseal it as well. You could also have a boat lift with solar cells on the top of it that could charge your batteries during the week when you are not using it. THen you get to run it down without even having to pay for electricity it took to charge the thing that week.
Unfortunately I am in no position to purchase your technology for that use and start up the manufacturing of such watercraft (if I won the lottery, then maybe we could start talking). I urge you to consider it and maybe even talk with companies like MerCruiser, Glastron, Bayliner, Volvo Penta, all those that deal with boats and share my idea with them. It is all just another step to lower the use of gasoline engines.
Thank you for your time.
Sincerily,
Stephen
Required 89A
Available 11A
Not counted:
- existing 40A EV charger circuit
- 70A circuit that connects a 120V PV system including a “cricitcal circuits” subpanel with eight 15/20A circuits (but the subpanel circuits were counted)
Obviously we depend upon the noncoincident load loophole. With our 100A main, we probably cannot legally install a 90A circuit for the Tesla charging station, so it will just have to run at lower power. Upgrading our panel is impractical due to an underground feed under the neighbor’s yard.
Being an electrical contractor the real question would be the figures that the local utility has used to feed the neighborhood. This won’t be an issue when only a few have electrical vehicles, but will come into play when they become a standard item. From what I understand some areas are already near the top end of their load capacity at times because of the increase in power consuming devices in the average house. Remember that many old houses only had a thirty or sixty amp service. Distributed power generation from solar and wind would help solve this problem.
I’ll do my homework soon
However, consider that there are other companies frequently installing accessories for homes in the same power requirement range.
I think that you would find a company that installed Spa’s and Hot Tubs on existing homes as a really good resource for information on what issues have to be dealt with from typical home electrical service.
“Usually, when a spa is connected to a dedicated 230 Volt line, its biggest requirement for the higher voltage is the electric heater. Most of these will have a heater element that is rated between 5000 and 6000 watts, and at this level of power, the element alone will draw between 20 to 25 Amps. Then add in the requirement for the pump(s) at 8 to 14 amps each… that’s a LOT of power”
www.spasupport.com/electrical/elex220.html
Unlike most houses, my peak demand is at night in the winter. This is because I have a heat pump. But, replacing the resistive furnace (120 amps @ 240 volts) with the heat pump (20 amps @ 240 volts) freed up a lot of capacity. I currently have 80 amps @240 volts available in my garage. 50 amps of that is an RV circuit. I just got rid of the RV, so when is the White Star hitting the market?
I’ll fill this out as soon as I have some free time, but, it’s easier to do the following estimate:
assume: nighttime use < average
average use from PG&E: 13kwh/day this past month, 13.7kwh/day the month before. Round up to 15kwh, divide by 120V and 24 hours = 5.2A
panel size: 200A
[Yeah, I realize that’s wildly optimistic, says nothing about instantaneous loads, blah blah blah, but really, our nighttime use of electricity is tiny — worst case dishwasher plus fridge plus rice-cooker plus parasitic loads]
It will be interesting to see the statistics showing the percent of those who will need significant electric service upgrades to support fast charging.
I’m sure many who have been postponing electric upgrades on their homes will use the charger installation as an opportunity/excuse to finally get them.
To simplify the customer experience with fast chargers, I’d suggest Tesla do the following:
- Certainly support automatic time shifting of fast charger use to midnight hours.
- Build in a few hundred dollars into the home charger option for a home consulting visit from a Tesla electrical expert (before electric upgrades and charger installation). The expert can outline electric upgrade options, especially if both a Roadster and a White Star purchase are planned.
- Employ or contract with specific electricians in your service area. They can not only install the fast charger, but provide upgrades where needed
to 200 Amp service. Elon’s “Solar City” connection might be a good resource to exploit.
- Compile an list of electrical contractor’s that Tesla owner’s have used and recommend.
- Explain to the Tesla buyer the net metering options such as double metering that some utilities offer. One of the meters provides special electric rates
for electric car owners. Recommended electricians experienced with this type of installation.
- Promote tax legislation such as tax forgiveness for electrical upgrades needed to support fast chargers. (as is currently done for solar panels
in California).
I assume most homes will need some upgrades, but the cost should be modest ($3,000-$5,000).
My home has 100 Amp service that would need to be upgraded to 200 Amps to support the assumed 70 Amp fast charger current draw.
When the girls at home turn on their hair blowers, the 100 Amp service is not enough even now.
Nicely done!
Missing in action - Hot water tank. Or did I miss not seeing it in the spreadsheet?
Why is the Motor Load section write-protected?
I unprotected the spreadsheet (Tools > Protection). Thank you for not password-protecting the spreadsheet.
I see that in order to get column entries to light up in the right column, we have to put data in the left column. My bad.
I changed the Electric Heater circuit entry for “pool” to “water”.
How do we get these spreadsheets back to you as feedback?
Editor’s response: Thanks for trying out the spreadsheet! Martin is looking for two numbers: your available ampacity and the required ampacity for your house as it is now. Please report them as a blog post, along with any feedback about the spreadsheet. (Review the “here is what I want from you” section of the blog, if you have additional questions.) If Martin has feedback to offer, I expect he’ll chime in here as well. (Martin added an electric water heater entry as a result of your feedback. It is in version 1.2 of the spreadsheet.)
Have you guys experimented with poly-phase charging circuits? Interesting blog Martin. Your right though, the NEC requires a good degree of skill and practice to interpret correctly. The way they word sentences in that book somtimes gives you the impression they are “trying” to confuse you. Anyway I’ll definately do the calculations for my residence if time permits. I’ve sooooo much other “electrical” homework to do first guys!!! Hehe.
For me it is 100 amp service. 14A free and 86 used. However if you look at the exclusions it would be rare for me to hit 5 major loads if I had a roadster charging in the garage. For example if I cook dinner, have clothes in the dryer, air conditioner and forced air furnace accompanying car charger. I had to guess for some of the appliances because there was no readily visible plate or sticker they weren’t on wheels. If I guessed I made sure to guess high. Not very scientific, but the best I can do at the moment.
I think people should also remember all the phantom loads in their homes - all those clock radios, stove clocks, instant on electronics, phone chargers and other consumers. If you don’t put them on kill switches they might add up to an amp or more. I know I was shocked when I realized how many of these devices I had around my own house. It may not help a great deal with the Fast Charger, but I know I shaved a few KWh off my electric bill by using some power bars I already had lying around.
To Strada - All new houses I have seen in Southern Ontario have 100 amp service. I have lived in two new houses in the Toronto area (905 belt) in the last 10 years. Both builders only installed 100A service and insisted I would never need more. Where have we heard similar statements in the technology industry?
One question - If someone has a solar installation is there any way to charge the car batteries directly from the DC power of the panels? There are losses converting the DC power from the panels to AC and I assume the car’s charger is also not 100% efficient. For the amount of power we are talking about even a couple percentage points would affect the number of panels. Hmmm, actually going 100% solar to charge a roadster anywhere in the Great Lakes region would require an awful lot of panels - surely more than I could afford, especially on the winter solstice
Here’s an idea: make your charger programmable, so that it will only draw the amount of power that the service can provide. The service technician could set this up when installing the charger.
Although upgraded service (from 100A to 200A in Virginia) only costs about $1000, and you can add as many spare breaker positions as you want, the “programmable” idea would make this solution much more ‘plug-and-play.’ Also, it might be possible to adjust the amount of current draw by the time of day.
As a response to the earlier blog referring to instantaneous load, I would assume that this charger, like most, would not just go ‘on’ and ‘off,’ but would rather ramp up the charge and ramp it back down to ease the effect of this on an electrical system (and on the batteries, as well).
Martin says: This is exactly how our charging system is designed: The installer sets a switch inside the home charging system that reflects the maximum charging rate allowed in the particular installation. Also, the car can already be programmed to begin charging at a given time, to take advantage of time-of-use charging and just to be a good citizen. The purpose of this survey is to answer two questions:
1) How many houses can actually support a 70-amp charge? Would it be worthwhile for us to create a less expensive, lower amperage charging unit for your garage.
2) Should we create a “time of use” option (that included an internal clock) for the charging unit that guarantees a lower charge rate during the daytime (when you might be using most of your house’s load), but still allows a decent charge rate at night? (I am not sure that the timer in the car would be sufficient to qualify for the loophole of NEC paragraph 220.60.)
Chris,
We are in 905, and in our neighborhood the homes have 200, you might have a point that builders would have gone to 100 in a cost saving measure. Builders and electrical contractors leave little room for expansion in the circuit breaker boxes that come standard in home or industrial applications. In an industrial application we have had to install an additional breaker box to accomodate additional circuits for lack of room in the existing breaker boxes.
If the Tesla fast charger requires 70 amps most private homes would be challenged to accomodate that level of amps, as an addition to the existing requirement of the home. Ideally the Tesla charger should not use more amps than a major appliance (electric range, clothes dryer, a/c) and it would charge at night.
The simple solution is the have the local electric company ‘drop’ a new service loop. This will avoid the need to modify your homes electrical system. Most are already crowded. Also, you will be able to easily see how much money you are saving every month by driving electric since you will get a seperate bill, and you can ask for a time of use meter that only works in the evening when the prices are lower……
I will take my complimentary roadster in red for such a good answer.
THANKS!
Frank Carter
Using the spreadsheet, my 200Amp service has a connected load of 177Amps and an available capacity of 23 Amps.
This is a fully loaded service when everything is on. This is almost never the case. A charging system is a “continuous load, more than three hours at a time” and must be circuited accordingly. Article 625 of the 2005 NEC also has requirements for vehicle charging systems. As an electrician, I am looking forward to all of the new work associated with electric vehicles. As you mentioned, control systems which create non-coincident loads are probably the least expensive method to create capacity for a vehicle charging system.
The spreadsheet says I have 112 required and 288 available. This based on pretty conservative guesses on my part about the nameplate loads and that my main service is 400 amps (I have 4 200 amp breakers connected by a bar).
Martin: I believe what you are looking for is the electrical amperage ‘headroom’ available for charging a car at my home. In my case, getting my usage number tracking down a circuit at a time will be problematic and error-prone. Could I suggest we use our electrical watt-hour meters to derive the actual usage. This would be a lot simpler and would include ALL loads. In my case, I would take a reading at 11:00 pm and then at 5:00 am (what we dedicated Tesla-ites will do knows no bounds). I would then subtract the two readings, divide by 6 to get KW’s, multiply by 1000 to get W’s and then divide by 240 (my meter measures at 240v) to get Amps. This would certainly be an average number over those 6 hours and would not include transient spikes when things like Air Conditioners switch on. Nonetheless I think I could get a better number this way and it would certainly be easier – except for the 5 am part.
Would this meet your needs?
Harley Dave
Martin says: No - The purpose of this exercise is not to measure *actual* headroom at all. Rather, it is to understand the code requirements for installation of an EV charging system in your home. When your electrician goes to pull a permit with your local building department, the building department will not be interested in your power meter measurements - they are building inspectors, after all. They care in a very single-minded way what, exactly, is the letter of the applicable building code - the electrical code in this case. My spreadsheet (and the work you need to do to fill out the spreadsheet) exactly interprets the applicable sections of the National Electrical Code to determine how much additional load the building department will allow you to add to your existing service.
You might argue that, even though my spreadsheet (and therefore the NEC) say that you don’t have enough headroom, you actually do, because many of your loads are not on at the same time. You would then need to demonstrate that you qualify for exemption through paragraph 220.60 (Noncoincident Loads), as transcribed above.
You might also argue that my spreadsheet (and therefore the NEC) says that you do have enough headroom when you in fact don’t (perhaps because of your fabulous collection of 1,000 vacuum tube clock radios that run all the time and are not accounted for in the NEC rules). This is your own judgment call - you can choose to upgrade your service if you want. Nothing dangerous will happen if you don’t - but you will trip your main breaker if your car starts charging when you have everything else on. But this is not an issue for your building department.
Note that some localities choose to add additional requirements above and beyond the NEC. This is getting to be more and more unusual in the US - there is a strong trend here toward uniformity of codes. But obviously, my spreadsheet cannot take into account local code differences.
I systematically filled out the spreadsheet. What a great tool.
Results:
Total required ampacity for 240V 1-phase Main Electrical Circuit = 115 A
Available ampacity in Main Electrical Circuit = -15 A (in red)
This seems to confirm my suspected need for an upgrade from 100 A service, even without the charger. Luckily, I rarely pop the main 100 amp circuit breaker, but it does happen.
Guess the NEC code is par for the course-try reading certain sections of the IBC for “more fun” (not). If you want to do a building with an enclosed atrium, some mech. engineers will decline to do the job because of all the mumbo jumbo involved. My Tesla power solution will definitely, no question , be those approx. 10′ x10′ solar panels via Solar City, or others. I’ll leave car home one day (at least)for charging purposes. Tesla should provide solar system with car purchase for as cheap as you can, as an added incentive.
I have to check my loads, but a thought in the meantime that could help for many situations:
If it’s practical, either design into the charger or create a separate load switching device to sit ahead of another large load to restrict to only one of the 2 loads at a time. For example, plug the charger (or load switching device) into the dryer’s outlet and then have an outlet in the charge (or other device) to plug the dryer into. At these loads, this wouldn’t be a cheap option but should be a lot less than installing a new circuit for the Thayer.
Spreadsheet (v1.2) result: total required 143, available ampacity 57. This includes a phantom load of 24 A for an electric dryer (we use propane).
165 required, 35 available
Service : 200 Amps
Required ampacity: 113A
Available ampacity: 87A
I got the power. Now all I need is 100Gs!
Editor’s note: Thanks for including your location!
Martin,
Appologies for wasting cyber space (I am in Italy and we have std 3.5kW or extra cost 5kW conections for homes here (ouch).
Could you not draw a signal from the meter box (do a deal with the Elcom) that tells what the house is actally drawing. the charger would use this to limit (to inputable preset) its output to never overdraw.
I’m sure its more complicated than this, but the idea is that you can never exceed your contract incurring the wrath of the elcom and go into overload cut out.
Mike
Ps how’s the new job going?
Just a note—you need to add an option that says something like: “cannot change electrical wiring because I live in an apartment” (that would be my situation).
I think this will be something that EV vehicle companies will have to anticipate/address in some way as they roll out this new technology more widely.
Parts of the grid are already highly stressed when all the air conditioners are running during hot spells. The same would be true of a substantial number of cars being charged at night. As far as hot tubs loading the grid, because almost all are well insulated and covered they don’t put much of a continuous load on the grid.
I think you’ll need a lower amperage station. Although 200 & 250 amp services are common, they tend to be on all electric homes. For me, the difference between a 3 hour charge and an 8 hour charge is meaningless. I get home, plug it in and unplug when I leave in the morning. Needing more than a half charge would be a rare event, 95% of my trips are under 80 miles. Actually, I can probably get by on the 15 amp/120 volt travel charger.
[Just a note to people: If you have two breakers connected by a bar, it is likely that each breaker is only 120 volts and interrupts one side of the 240.]
I have what I consider a pretty typical setup in my parts.
200A Service, power is cheap here ~ 6.5 cents per KW/hr Peak & Off Peak averaged together.
Gas Heat
Gas water heater
My home is just shy of needing dual HVAC systems, ~2500 sq ft.
I have over 80Amps free.
The problem I see is that may of your customers (at least until the blue star) are going to be upscale financially, and typical homes will have Dual HVAC systems, a whirlpool bath, more light circuits, flood lights on at night, hot tubs and/or in-ground swimming pools with pumps or heaters running at night. Many of these homes still have 200A circuits.
Editor’s comment: Thanks for the update. Have you run the numbers on the spreadsheet? If so, it would be great if you could report the numbers in the top, left corner of the sheet — required and available amps — as noted in the “here is what I want from you” section of Martin’s blog.
# Editor’s comment: Thanks for the update, TEG. Martin is looking for both the “required” number and the “available” number.
If I leave off the existing 32A Avcon, then I have 51A required, 49A available…
(My range, water heater, and dryer are all gas so I don’t have those as load items)
The results from my house (built in the mid 70’s, about 2300 sq ft) indicate that I am using 85 Amps out of the 100 Amps available leaving only 15 Amps available for a charger.
As others have noted the load calculation is assuming that “most” appliances are on. Given that I would arrive home, plug in the roadster to charge, start dinner (using the oven) and maybe a load of wash (using the dryer), I can easily see where I could be using a substantial amount of electricity. The ability to start the charge at say 10 or 11 that night (off peak usage time) would help to eliminate this problem and potentially save money.
If I increase my service load and so do a few of my neighbors PG&E will need to increase the size of the transformers and feed lines from the main distribution center. PG&E just replaced the transformer servicing our neighborhood due to the number of air conditioners. Now with potential addition of chargers, they will need to do that again in the near future.
Editor’s response: Would you mind confirming the numbers for me? We are looking for the required and available amps, as reported in the top, left corner of Martin’s spreadsheet. I just want to make sure we’re recording the correct numbers. Take a look at the way Steven Casner and Phil H. reported their numbers for an example. Feel free to add notes and comments below the numbers.
Martin: Got it. Sorry about that. The number you’re looking for is (A), that allowed by the building inspector. The number I was producing is (B), that allowed by my main breaker. I’m actually going to do both. If (A) is less than (B) then everything’s OK. If (A) is greater than (B) I could start popping breakers. So I really want min(A,B).
SPREADSHEET GLICH(V1.2): Central Vacs. Every entry in Step 2 generates one or more entries in Step 3…except Central Vacs. Enter (1) for Central Vacs in Step 2 and nothing appears in Step 3. The answer at the top tells me “step 3 incomplete” when I’m not being allowed to complete it. I’ve unlocked the spreadsheet and can fix it myself, but I think I should wait for official update.
Editor’s comment. You are right! Martin has updated the spreadsheet. Look for version 1.3. (Version number is at the bottom, left of the spreadsheet.) If you don’t see version 1.3, clear your browser cache. (If you need help clearing your cache, here is a good resource.)
As an electrician and electrical instructor, I agree that the NEC is a bit difficult to sort out. Your spreadsheet is very good for new residential services, however the situation you describe is that of adding a new load to an existing residential service. This is much easier to figure out if you use Article 220.83 (A) titled “existing dwelling unit”. This is the calculation I would use to get a permit. It is much easier and the calculated available capacity is significantly higher than that shown by the spreadsheet. Remember to also look at Article 625 and identify wiring method and ventilation details required there for the permit.
Martin says:
“1) How many houses can actually support a 70-amp charge? Would it be worthwhile for us to create a less expensive, lower amperage charging unit for your garage.”
I don’t mean to undermine you, but I want to point something out just in case by some chance, you missed this.
The people who are buying the Roadster (obviously) have cash, and I’m sure they’ll spend some cash to upgrade their wiring in their house if needed/wanted.
Unless the charger is going to be of use by your future vehicles, why clamor over a charger that’ll only have problems with maybe a couple of your customers. (or “members”) And the only “problem” is that they wouldn’t be able to cahrge quickly, so really, what is the problem then?
Of course, if the charger is going to be in use for your future vehicles, ro if you think it’s worth the possible cost reduction, then it’d make sense. You’re the boss! I’ll be posting soon the info.
Required: 188 A
Available: 12 A
Location is Maryland. Using Open Office Spreadsheet (V2.0) on Ubuntu Linux instead of Excel, and the it seems to be calculating and generally behaving properly. I’ll double check figures on a Windooze machine when I get a chance.
The numbers make sense in terms of the ratings of the circuits and appliances, but not for real life. My heatpump has a huge resistance heater for the 3 days a year when it’s too cold here for the heatpump to work properly. That alone accounts for 50 of the 188 amps. Another 62 are represented by the self-cleaning electric range running with all four burners full on, the oven at max temp. and the broiler full on.
So if I don’t try to charge the Tesla on the coldest day of the year, while simultaneously attempting to ignite the house with my stove, and running the dishwasher, clothes washer, clothes dryer, and every light and other appliance in the house, I should be ok.
I hearby invoke NEC paragraph 220.60, Noncoincident Loads.
PS. Reminds me of the old Green Acres show, (It’s the place to be!) where the wife Lisa had all the appliances numbered according to how much power they used. She would have to unplug one to use another, to keep them under some total number to keep from blowing the fuse. Then Oliver would want some coffee, plug in the coffee pot, and knock out all the power.
Total required ampacity for 240V 1-phase Main Electrical Service 120 A
Available ampacity in Main Electrical Service 80 A
Required: 96
Available: 104
If I want to use my vehicle as a battery backup for the home in case of power outage, where would I find instructions to provide the electrician on how to set up the circuit I need to run to the garage? I just had an electrician in and I was told that they couldn’t do it without running two separate lines (one to provide power to the car, and the other to recieve power during a power outage)! I have trouble believing that this is true.
Hey guys, thanks for the spreadsheet; I needed to figure out how my loads were doing anyway! I’m just about to start, so I’ll report back soon, though I’m positive it’ll be way low…of course, I’m well below the income level of your potential customers anyhow. (Don’t you think a full survey that asked a few more questions about income, current vehicle cost, and maybe home age/value might be more worthwhile? This seems kind of like shooting from the hip here…)
Anyway, just dropped in to wonder about the feasibility of a “dump charger” arrangement. If I were to stack up 50kWh worth of lead-acid batteries in my garage and let them charge overnight at 6kW or so (on a 30A 220V breaker) or all day/night at 2kW (on a 10A), how fast could I dump this into the roadster? I guess in truth one would probably need somewhat more capacity than that to account for charging inefficiencies and the fact that lead-acid batteries don’t like being run too far down, but you get the point…could a battery-based charging system be an option for those without much headroom in their electrical service? Could it be even faster than the fast-charger? I suppose given any high-voltage-capable dc charging system it would be easy to rig the battery part, so it’s a similar question to the guy looking to do the solar thing.
I’ll get back to you when I’ve finished this spreadsheet…
Now I’m a little worried. Does the home charging unit actualy require 70 amp service, or can it get by with less, say a 30 amp service and just take a little longer to charge?
Editor’s response: The Home Charging Station delivers the quickest charge with a 70-amp circuit, but it can be set up to work with smaller circuits, as Martin mentioned in a previous comment. You are correct in your assumption that smaller circuits mean longer charge times.
Required: 135A
Available: -35A
Main: 100A
My electric range, A/C, and dryer apparently use 100A by themselves. I never actually trip the main breaker because the devices never use anything close to the total amps allocated to them.
The “noncoincident load” loophole definitely applies to me, as some of the biggest power hogs (range, dryer) aren’t used overnight. Unfortunately, since I’m already overallocated, I’m not sure if the electric code would allow me to charge at all during the day. But, I’m willing to upgrade to 200A service if an EV needs it
I have similar observation to Phil’s above. I havn’t checked yet, but I’d likely have 40 to 50 easily available amps, and more if we did a formalized swtiching thing with one of the 50amp 240v circuits. But the real issue is going to be nieghborhood upgrades should more than a few people in our part of town go with a higher energy use electric car (tesla or not).
Fascinating car, but I´m missing a few things. First what´s the drag-co of the roadster, can´t find it any where on the website., secondly couldn´t one option be to replace the sidemirrors with small cameras which display it on the central screen to improve the drag-co or is that just hair-splitting?
I did put in the numbers for excel, but I think I might be a little off: all in total, off by maximum 2000 watts? I couldn’t find numbers for many of the appliances, even online.
I live in South Florida. ~2,500 square feet home. Max of 200 amps on the system. Results are…
Required Ampacity is 122 amps.
Amps left over is 78 amps.
I’m surprised by the relatively small number of people who have participated. Help Tesla Motors!
San Carlos House
Required - 86A
Available - 64A
Hillsborough House
Required - 90A
Available - 110A
Pacifica 4-Plex [where my Roadster funds went for a down-payment]
Required - 39A
Available - 11A
*** This building has 4 units. Each individual unit has the above results.
I would have ran the numbers for the small industrial building we have (just in case I wanted to make a studio in one of the units) but I don’t think the spreadsheet supports 3-phase.
Can I be in the beta test?
Woot! : )
Main: 200 A
Amperes Required: 96 A
Amperes Available: 104 A
~ Power Available: 24,960 W
I live in an appartement building in Singapore, as 70-80% of Singapore does. This makes for organised parking lots with substantial power feeds for the appartment building. 2 small problems do present themselves.
The first is pulling together the right support to install the charging stations. Secondly eventhough Singapore is probably the worlds best test ground for electrical cars (city state, with some high ways (max. 90km/hr), limited distance of travel on average, a rich nation (plenty Ferrari, Porsche, Lambo’s), tech savvy, a forward looking decisive government), there are no electric cars (only some hybrids)! When are you coming to Singapore again?
Further I have seen some reports on prototypes from Mitsubishi and Volvo (via www.gizmag.com), they opt for in-wheel electric motors. Having read this blog for some time I was somewhat surprised to see this developments as the arguments against the in-wheel motors seems substantial. Is this window dressing or actually a feasible solution?
Good Luck,
BW
Service: 200 Amps
House is wired with Electric Dryer Outlet but equiped with a Gas Dryer
With unused electric dryer outlet included:
Required ampacity: 140A
Available ampacity: 60A
With unused electric dryer outlet removed:
Required ampacity: 119A
Available ampacity: 81A
Last year I installed a ground source heat pump and replaced all my gas appliances with high efficiency electrical appliances (such as an induction cooktop), so I made up a similar spreadsheet (not quite as nice, though) based on 220.30.
My sheet:
Required: 143 A
Available: 7 A
Martin’s sheet:
Required: 164 A
Available: -14 A
I need to find the discrepancy. At the time the electrician and inspector agreed with me.
Applying 220.60 to Martin’s sheet, I get:
Required: 111 A
Available: 39 A
The utilities here in MN typically use a load control receiver to control large loads if you want to qualify for interruptable (cheaper) or off-peak (cheapest) rates. The charger would therefore need to be controllable via the low voltage (lt 24 V, lt 1 A) relay in the LCR.
Mark, I have a brilliant and infinitely expandable way to power cars. The Potential Energy Machine. A Machine designed for one reason - to store and release massive amounts of potential energy. It may rely on magnetics.
Email me for the CAD files!
V1.3 working fine. I have 400 amps at the breaker (Power to the People!). Spreadsheet results:
Required Ampacity: 126
Available Ampacity: 274
So much for the Building Inspector. But what am I really using? It better not be anything like 126 amps. Using my watt-hour meter and taking readings at 11:00 pm and 5:00 am, my average usage during the window that I would be charging my car is: 29 amps, which explains why my electric bill isn’t close to the national debt.
The next issue is power utility capacity. Having lived through California brownouts during 10 years in silicon valley, nobody’s breakers were popping, we just didn’t have enough juice from PG&E during hot months when we all had our AC’s running at the same time. If everyone in Atlanta charges their car during the same window and approaches their breaker capacity, we’ll have the same problem here.
I will see if I can find the information on my residence, some of the equipment is installed in a manner that direct viewing o the plates may not be possible (if they are still on, the AC unit is a museum piece).
I have seen a case where a house had additional load added to it, though I was young I can’t cite too much of the process, cost or specifics. My mom ran a home business making ceramics. She had 3 kilns for firing the clay. These kilns drew more power than the house was rated. An additional line was dropped, and an additional circuit breaker panel for the 220v service installed. Time may have made my memory inaccurate, but I recall figures like 30, 40 & 100 amp breakers on that panel. If you have something like an EV charger that exceeds the service to the house, I believe it is possible to get a variance and have the service installed to meet the demand based on this. The cost factor I do not know, though on my residence I have investigated replacing the existing ancient panel (that doesn’t meet current codes) and relocating it indoors, the cost being estimated around $1,500 for that exercise.
Alexmcfire, the Tesla Roadster has a Drag Co. of .30
I think my post of the electrical capacity of my home didn’t get past the editor. I’ll post it again just in case. It was something like…
Required: about 125 ampi
Left over: about 75 amps
I made alot guesses on the power use of the appliances though. I couldn’t find the power use of the appliances on the internet or through the oweners guides. Instead I found websItes that listed the average power use of different appliances and just went along with that.
Editor’s note: We published your previous post with results on September 7.
Required: 304A
Available: 96A
We’re in Sammamish, WA (reasonably mild weather year-round).
We have 2x 200A panels (panel #2 can be powered by a generator). Interestingly, if I spreadsheet them separately, assuming half the square footage for each, I get the following:
Req’d/Avail #1: 256, -56
Req’d/Avail #2: 56, 144
Unfortunately, the overloaded one is where the Tesla charger should go.
Our largest amperage circuits now (A/C and oven) are 50A.
Required: 204
Available: 200
Its quite a project to find all those numbers on those old nameplates - but it sure was interesting to see just how many things run on electricity in our house. The self-cleaning double oven plus all the cooktop burners really pull a lot of Amps.
Perhaps some sort of a clamp-on current monitor could be put in the main box to continuously measure the current draw and used to control the EV charging rate. This could make sure the full 70Amp charging is only done when the house is not drawing too much - which is probably all the time.
Hurry!
Tesla Roadster in Gran Turismo!!
www.autobloggreen.com/2007/09/09/video-tesla-in-project-gotham-racing-4-ad/
You can see how the youtube videos reflect the commercial, and we can finally see the Roadster in all its digital glory!!!
However, in the commercial we cannot hear the Roadster producing its turbine-like symphony….
Editor’s comment: This is a commercial for Microsoft’s Project Gotham Racing 4. The Xbox game should be out in October.
just remember all the people who are waiting impatiently for you to create a more affordable car. I, as one of those people say, if your TESLA can do all this, i’m sure you can make another electric car with 1/3 of power, speed, etc at 1/3 the price….{as long as we can still get that 200+ miles to the charge
I support your company more than any of the big boys because of your true desire to rid us of our addiction to oil and other fossil fuels…please beat them to the punch and get a more affordable electric car out there…..i will be your first customer.
thank you for letting me post…
Great tool… no time to do the leg work eight now, so its on my to do list.
Question: Has Tesla considered packaged (”solutions”) sales, partnering with local solar infrastructure providers? I’ve got to think the overlap in customer bases is large and sympathetic, and the retail solar firms seem to be hot. [Sorry for the pun flaring up]
Personally, if I’m getting a White Star I’m going to want to use the opportunity to go solar electric. (Please get the White Star rolling out soon, not sure how many years of $500+/month electric bills I can take..)
As currently configured, I come up with 154A required, 46A available. However, I do have 2 water pump circuits no longer in use, which would bring it to 138/62. If I also removed the 30A garage circuit (originally for an EV), I get 120/80. So with little work I could come up with enough to run the fastest charge even ignoring the concurrent load loophole, but frankly I would probably just stick with the 240V 30A circuit already available as I envision only charging overnight.
Jay
Nicasio, CA (2400 sq. ft. built in 1976)
I get 110A required, 90A available.
I have 2 heat pumps which I included as “air conditioning”. They are very efficient so we almost never use the resistance heater.
The house was built as “all electric”. We converted the water heater and stovetop to propane.
I also have a big arc welder (60A 240V) which I almost never use at 3am (so I didn’t count it)…
And, I just had the service panel replaced. It was an old Zinsco piece of junk. If you have one, replace it.
Now it sports a brand new 90A 240V “car charging circuit” ( conduit under the driveway and everything). All I need is the car…
Along with the GM “Volt” trying to take some of Tesla’s thunder, comes the new Volvo “Re-Charge” plug-in series hybrid:
www.autobloggreen.com/2007/09/06/frankfurt-preview-volvo-recharge-the-swedes-go-series-hybrid/
“flabby wrote on September 5th, 2007 at 10:56 pm
165 required, 35 available”
PS. My location is Concord, Ca
Have you also looked at this online tool?
northwestsolarcenter.org/Resource/loadsize.html
Bas, problem as I see it is that Singapore only allow RHD (Right hand drive) cars for Singapore residents?
Joesph, thanks for the info.
Total required: 181A
Available: 19A
Location: Sumter, SC (in a new subdivision, house is 8 mo. old.)
Comment: Geez, people! The man just wanted a string of replies that read as above. Figures after figures, not all the extraneous comments! (Of course that’s exactly what I’m doing here…)
I have a 100 amp electrical service panel. After filling out your survey, I found out it is undersized for the house as is. No surprise here since many accessories such as central A/C, a pool and a room addition have been complete over the years. However, considering the car would charge overnight I do not see a problem with it. If I found there was a problem, I would be willing to upgrade the electrical service panel.
Residence built 1991
Req’d: 154A Avail: 46A
I like the idea of the concurrent load loophole and believe I would qualify. However, because SMUD offers EV charging at rates 1/2 of regular residential rates, the minimum effort to modify the existing panel to provide for the required new separate meter, I am inclined to go the route of expanding capacity with a completely new panel at a relatively modest additional expense. The incremental effort/expense would therefore provide capacity for the 70A (90A circuit) home charger.
I did the calculations and I got the following results:
Required: 120 A
Available 5 A
Please, keep in mind that:
1. I calculated two ovens for 30 A (110V) each, but actually I never used the second one.
2. I have solar panels installed on my roof, so my electric bill is always 0.
I look forward for the White Star!
Keep up the great work.
Does anyone know why Ian Wright stopped working at Tesla to start his own venture? Given the history working with Martin before Tesla on conversions I would think that is a natural fit. What did he want to do that he could’t at tesla? If anyone has information on this please post. Thanks!
I have two houses, one with 200A service and the other with 400A service. Both include 50A 240V service for a welder. Since the welding is a hobby, there is a good 50A available most of the time. In the house with the 400A service, extra capacity was included with the idea of adding an elevator some day (100A). The elevator was never installed so I have an additional 100A . Then there is the office, it has 600A service and since we don’t manufacture any more (cheap foreign labor) I have around 400A available there. A big charger shouldn’t be a problem. What I would really like is a small fuel cell (or genset) option that I can put in the golf bag hole (I don’t golf).
Maybe I missed it, but why hasn’t anyone mentioned alternative circuits. Up here in Saint Paul, MN, my garage not only has the typical 15A/120v system, but also a dedicated 20A/120v circuit for an air compressor and 60A/240v for an arc welder.
we never use the 20 ampere circuit because frankly, the neighborhood kids think the air compressor will eat them if they cross our lawn. Yes, it really is that scary. My grandfather built it himself, and in the early Seventy’s liability wasn’t an issue. So now, it sits in a dusty corner with its plug removed (for the sake of young children’s’ fingers everywhere).
As for the welder, the last time IT was used was to construct the afore mentioned Digit Dicer.
So, Tesla has many options for charging circuits. I think at least one model of your charger should be capable of 20 amps at 120 volts, because commercial buildings are almost always equipped with 20 amp branch circuits to run those ride-on floor waxers. This way, i could always grab a quick charge during lunch at Tobie’s on my way to go skiing in Duluth ;^}
We should also be able to simply order our chargers with a PLUG for use on the otherwise abandoned welder and/or dryer circuit that resides in so many garages.
A couple notes on my previous post. I reran the numbers on Windows, and got the same results, so it does appear that the spreadsheet worked properly using Openoffice on Linux.
Also, I checked the size of my service conductors, and they are rated 400 Amps. This is standard around here. So I could probably just replace my load panel with a higher capacity one and fairly easily upgrade my service. At least the power company wouldn’t need to run new service conductors.
Also, I don’t think the spreadsheet takes into account the calcuations is 220.83 and 220.84, or does it? Not sure if those sections make any sense or not.
I am approaching this from a different angle.
I would rather buy my “gas station” along with my Roadster, and I want it to be solar. My new home will be 100% off the grid with a 5KWH system feeding a small 2.4KHW energy budget. I’d like to charge my car anytime of the day using solar power, but especially during peak sunlight hours.
So, I am simply seeking to design a separate, dedicated solar array around the needs of the car and the garage/apartment/workshop, while not requiring more solar PV panels than the space station. I work at home and will probably only charge the car twice to four times a week. I would sell the excess power to the grid.
I’ve seen 110V and 220V used interchangeably in these posts, but 70A and 110V seems to be mentioned the most frequently.
So, I am thinking a dedicated solar system capable of handling a sustained 7.7+ KW AC load for up to 4 hours is sufficient to charge up the Roadster, and then I’ll add capacity for the garage apartment itself. Correct?
- JonE
Simple solution for many. With the electric dryer 220 plug in the garage, have a charger unit that has a plug pass through for the dryer, so when the dryer is not in use, the circut is available for the charger. In this way no special wiring or permit is required. A solution for many, but not all.
Service : 100 Amps
Required ampacity: 85A
Available ampacity: 16A
The results from my house (built in the mid 70’s, about 2300 sq ft) indicate that I am using 85 Amps out of the 100 Amps available leaving only 15 Amps (rounding) available for a charger.
To EV1 nut: We’re mostly dealing with the Main service, and how much is left after accounting for all your appliances. The idea behind the Tesla Home Charger is that it gets its own circuit off the main, or maybe borrows the dryer circuit or something.
A 20 amp / 120 volt circuit would take over 20 hours to recharge a Tesla Roadster battery… way too little power for a “quick top off during lunch”. Any EV is going to need at least 220 volts and as many amps as possible to get a reasonable charge rate. Tesla’s claimed “3.5 hour charge” assumes a 230 volt 70 amp service, for example.
To jon ellis: Tesla is planning to co-market with Solar City to cross-sell solar panels. These wouldn’t be exclusively dedicated to your car though–they add to your household grid service so when you’re not charging your car, they can lower (or reverse) your electric bill.
Charging at night is no big deal even if you have solar; your meter spins backward in the day, and forwards at night, balancing things out
For new construction in Oakland county, MI - should you install a heat pump / geo-thermal furnace, DTE Energy insist on 2×200A main panels! The geo, hot water, electric drver etc can run off ‘Time of Day & Electric Vehicle’ meter, which is charged at half the rate of the other 200A service for lighting, cooking etc. Lots of capacity for a 70Amp charging circuit!
In the Tesla blog “Powering the Tesla Roadster with ‘Green’ Electrons” by Dr. Rob Wilder, CEO of WilderShares LLC, is planning to charge his car on only a 3.85KWH solar system. Perhaps I’m overpowering my solar charging system?
Would a 30A 120V socket do just fine, maybe just take 6 hours to charge?
- JonE
jon ellis wrote on September 12th, 2007 at 3:03 am
Jon raises a good guestion:
“I’ve seen 110V and 220V used interchangeably in these posts, but 70A and 110V seems to be mentioned the most frequently.”
I want to make sure I understand the amperage requirement for charging. It comes down to watts and then volts. Assuming I want to fully charge all 50kWH of battery in 6 hours, that will take 8333 watts (50,000 WH/6 H). If this is delivered at 120 volts that works out to 70 Amps. If it’s at 240 volts that’s 35 Amps. So the question: is the charger 240 or 120, or are there two different chargers?
Our place came out to 85 amps available counting everything. If I drop out the waterheater that is only used to store hot water from a water source heat pump and the backup heat for the same system, the available is 151 amps. (We have a 400 amp service.)
The reality is that the utilily transformer has a secondary fuse of 105 amp! (25kva transformer) If I were to turn on the backup heat on the watersource heat pump (15kva), the oven, the heat pump its self, and both water heaters, the utility fuse would clear, but in fifteen years the only power failure on the property was due to a squirl. (rip)
Powering an electric car at $0.16 per kilowatt/hr charging a battery with 35 kw of energy will cost at least $5.60 and this assumes 100 % efficiency and that rates won’t go up, which they are. This gives you enough power to go about a hundred miles. This is puts it in the range of diesels, of which several are currently being produced by BMW, Honda, VW and several others that get around fifty miles per gallon. It looks like a race between diesels powered by algae based biodiesel and pure electrics powered by energy generated from alternative sources. I think the winner will be a diesel serial hybrid wtih batteries giving the vehicle a range of 30 to 60 miles that can be plugged in at night. This solves the problem of range and infastructure. A battery pack that only has to provide a range of 40 miles is almost affordable right now and the costs are coming down and advanced diesels that run at a constant rpm are highly efficient right now and only getting better. A small capacitor for power recovery would make this vehicle extremely efficient.
I notice a lot of posters have much higher power requirements than what I came up with for my house.
I suspect some is because those are larger houses with more appliances, but also some of it is that I had favored natural gas over electricity for some things.
For instance, my stovetop is gas, water heater is gas, central heat is gas, & dryer is gas.
(We did go with an electric oven to get the self-cleaning feature).
Now that I have solar panels covering all my power needs, I wonder (in hindsight) if I should have gone with more electric appliances instead of gas.
How do people feel about this? Are some of you more “pro electric” for appliances than others?
I tend to think that gas dryers, water heaters, central heat, and stove tops work better than their electric counterparts.
Service: 200A
Required: 49A
Available: 151A
Survey says…
112 A Required
-12 A Available
This is with a electric dryer, we use natural gas.
Without this the results are:
88 A Req
12 A Avail
I should also mention that we are in the Chicago suburbs and that an upgrade to 200 Amps service is available for about $1000. We rarely blow any fuses (yes it’s an actual fuse box
I went through your spreadsheet as asked and the numbers I got are:
Total required ampacity for 240V 1-phase Main Electrical Service: 87 A
Available ampacity in Main Electrical Service: 113 A
Thanks,
Brian
With some assumptions, 24 available on a 200 amp panel in Oakland, CA.
That 400 amp panel ain’t cheap, either!
p.s. thanks for the cool spreadsheet, I was trying to back into this on my own and this is much easier
pps. any idea on the timeframe for making the “build mechanism for nighttime only” decision? I was going to have the electrician start work pretty soon for this, but obviously would love to avoid the 400 amp main if I could!
Service : 200 Amps
Required ampacity: 126A
Available ampacity: 74A
media.chrysler.com/newsrelease.do?id=7294&mid=1
…” Auburn Hills, Mich., Sep 13, 2007 - Chrysler LLC announced today the creation of ENVI — a new organization responsible for bringing electric-drive vehicles and related advanced-propulsion technologies to market. Lou Rhodes has been appointed President — ENVI. “…
# Harley Dave wrote on September 12th, 2007 at 2:08 pm
## Jon raises a good guestion:
## “I’ve seen 110V and 220V used interchangeably in these posts, but 70A and 110V seems to be mentioned the most frequently.”
## I want to make sure I understand the amperage requirement for charging.
## It comes down to watts and then volts. Assuming I want to fully charge all 50kWH of battery in 6 hours,
## that will take 8333 watts (50,000 WH/6 H).
## If this is delivered at 120 volts that works out to 70 Amps.
## If it’s at 240 volts that’s 35 Amps. So the question: is the charger 240 or 120, or are there two different chargers?
I don’t know the facts for sure, but my guesses are that there will be more than one 240v charger, and one for 120v.
The preferred charger would be the 240V 70amp that can charge the roadster in 3.5 hours.
Then there would be a lower amperage (~35AMP?) 240V portable charger to hook up at campgrounds and such to RV plugs (like NEMA14-50).
I am guessing that this blog is trying to find if there is interest in a “mid-range” charger option… Perhaps 50AMPS @240Volts for those who don’t have 70AMPs @ 240V available.
I think the “last resort” charger would be a mobile 120V charger, perhaps configurable for different current draw, but a common one might be only 12AMPs or so.
So, bottom line, you want 240Volts if you are setting up any kind of permanent charging station. The more amps the better, but there may be a few options depending on how many AMPs you can get. The highest current chargers likely involve permanent wiring. If you have to use a “mobile adapter” then you may be limited to recharge times 2x what you would get from a permanent charger.
Someone at Tesla can probably give you more accurate information if you need to make plans.
To TEG2: Natural gas is extremely efficient for heating purposes… but it’s a fossil fuel, so we’ll inevitably hit a supply crunch and, ultimately, depletion.
If you can get natural gas cheaply, by all means stick with it
Just save some room in the budget to start switching things to electric in the future
A lot of people are concerned about the extra load EVs will place on the grid, but it’s nothing in comparison to the load that’ll happen when people are forced to start switching their heaters to electric en masse.
I find it interesting that no one is addressing the total cost of electricity both economically and environmentally. It looks like when you add everything up, a pure electric isn’t the way to go. A plug in serial algae biodiesel fuelded diesel hybrid looks like the way to go when all factors are taken into consideration. It would be able to take advantage on alternative electric generation and in the meantime could use regular diesel and electric power. A vehicle of this type would get about sixty miles per gallon for a small sedan, probably better. Ford is about to release a Focus that gets 54 mpg. Does Tesla have any plans for an auxillary power unit?
Editor’s note: You might want to take a look at our white paper, The 21st Century Car.
martin:
required: 97
available: 3
this is ~25 year old condo in hoboken, new jersey.
one alternative that i have not seen discussed is that the charging station can actually take a charge itself, perhaps using an almost identical battery pack as in the car. this way, the station can charge itself during off-peak hours (or top off more slowly during peak hours if this is desired), and a full charge at the ideal amperage is always at the ready. ironically, certain hybrids work the same way, except the power souce comes form the internal combustion engine rather than the grid. the benefits of this option are that the load on an existing electical system is minimal, the cost to charge is minimized, and the station is always ready to fully charge the car at the ideal rate in the quickest time. the drawbacks are that the station gets larger (must be the size of the battery pack, although the dimensions can be adjusted), and these batteries will require replacement just as those int he car will (in a way it doubles the future battery replacement costs). however, rewiring, etc. may cost upwards of $1k, so this is not as bad as it seems.
~ian
Hi Martin:
A company in Canada www.triactapower.com has been collecting data on power usage in homes (and business) for the last 3-4 years. You should contact them and see if they have the data you need.
-Lawrence-
I will be running down all the numbers for my home here in San Mateo, CA this weekend but in the meantime I have one question for you and that is: besides the Whitestar (when will pictures be available?) is there a Tesla pickup truck in development? Maybe I’m wrong but this will be VERY popular with those of us who have pickups and SUVs, not to mention utility fleets. Martin, can you shed any light on this?
How about an online spreadsheet that is published through one of the online document repositories, like docs.google.com or thinkfreedocs.com? That way everybody gets the latest info without version numbers….
Editor’s comment: Thanks for the suggestion. We will consider that next time we publish something like this.
I was curious about the charging unit that comes with the Roadster. For those people who install solar panels in their homes and wish to use them to charge the car, does the charger even accept 12V DC, or do you require it go through the lossy conversion to AC just to be converted back to DC by the charging unit ?
Dear Editor, I read the white paper and it didn’t have any figures for a serial hybrid with plug in potential. Also algae based biodiesel(which is coming on very fast from DeBeers and other reputuable large and small companies) has lower pollution than regular diesel due to containing 11% oxygen, consumes co2 and sewage during production, has a higher octane rating than regular diesel, contains no sulfer or metals, burns better than regular diesel and makes the engine last longer. Serial hybrid diesels are in use in Holland in busses and they get 15 mpg on 32 passenger busses in stop and go city driving. So in theory and demonstration it looks like the serial hybrid diesel is the clear winner. As I’ve mentioned before, an Advanced Propulsion Technologies diesel(these are proven and being sold in quantaties to the US military and others) coupled to a Tesla looks like the best option from all angles. Any comments or views on this would be appreciated. Public vetting is the best way to clean up any flaws or misconceptions.
One othe note, one of the biproducts from producing biodiesel from algae is the ultra efficient production of large amounts of high protien animal field per acre.
Not sure how to attach spreadsheet. Basic info: 2700 ft2, 200 Amp Main, Only major appliance is electric oven rated 5.9 kilowatts.
Currently we have 3 KW solar panels in Long Beach, CA and are on time of use billing with So. Cal Edison. We are charging an electric Xebra PK on a night time circuit (110 volts/20 amp) that needs 4.5 KW for 17 miles of driving. Look forward to the next Tesla car so we can use our solar panel production will offset nearly all of our driving!! Thanks for your efforts.
Editor’s note: Martin is looking for the two numbers in the top, left of the spreadsheet — available Amps and required Amps. No need to send the whole spreadsheet. Thanks for participating!
Total required ampacity for 240V 1-phase Main Electrical Service 141 A
Available ampacity in Main Electrical Service 59 A
Dear Tesla Motors,
Stephen brought up the idea of using the Tesla Electric technology in a marine application. A significant opportunity exists in the sailboat re-power market. Numerous good sailboats from the 1970’s exist, but their engines are their undoing. Repowering a 27-45′ sailboat starts at roughly $8K just for the diesel, and due to the heavy, clumsy shape of the new engine (as well as the old one) the cost of the gear to get the old one out and the new one in plus interfaces, costs another 7K even doing most of the work by yourself.
Installation of a Tesla Battery and a range 20 to 50 Hp motors would be ideal for this application. Most sailboats use the engine to manuever in and out of the marina, so battery cycle drain would be minimal except on that long trip a year that might be taken. Standard shore power hookup at marinas require 30 Amp shore cables, with 20 Amps usually available at the dock box. As Stephen points out, boats are usually just sitting around Mon-Friday, so solar panels could bring the battery back up from at least a .5 hour of use the weekend before. Even a 1.5×4′ flexible solar panel was good for putting 30Ah+ back into a 12V battery M-F on my old boat. A 30′ sailboat could fit 5 of those easily. Many cruising boats employ the more efficient hard solar panels with wind or towed generators.
Compared to a Tesla, $10-15K isn’t very much money, but the engineering is straightforward/easier, no NHTSA safety specs to worry about, no suspension, etc. This could be a nice source of revenue for your firm now, until funding for mass production of electric vehicles is a reality.
Regards,
Roger
I ran the spreadsheet with no problems, although time consuming. Home has 300 Amp supply of which 240 is allocated and 60 is free. Our pool heater is a heat pump and tried to enter it under motors but was not permitted to enter 240V. Entered under “pool heater”.
What is availability of A123 technology for Whitestar? Has GM’s reltionship blocked you from access?
I am a Tesla member and customer in Walnut Creek. Like two other posters here, I live in a condominium and do not have a garage; I only have an assigned (covered) parking space. I will need to get approval from the HOA for the charging unit to be installed on one of the pylons supporting the cover structure. I have already spoken with some Tesla personnel about a shell/protective covering for the unit, which sounds doable. The bigger challenge will be figuring out how to run a power source to the unit, and how to assure that I am properly billed for it individually. I think it would be helpful for Tesla to provide some links/resources on who to consult with to get the proper information on how to make this a reality. I have a call in to PG&E, but so far they have not responded to my inquiry. Will it be possible to install a new meter for my needs at a different location from the meter that goes to my unit? How much will this cost, etc.? Would it be possible to install solar panels on the roof of them covered parking structure and feed the power therefrom directly into the charging unit? It would be good to have a central resource to consult for some of these questions, that was responsive. I think this will continue to be an issue as EVs spread to condo and apartment dwellers along with homeowners, as others on the site have already mentioned. I think it would be worthwhile, and smooth the way for greater EV market expansion, if Tesla would partner with/refer to local utilities in its key markets to develop a master list of applicable contact people at the utility and liaisons at Tesla, so that implementation specs can be centralized and experiences distilled into a standardized menu of possible procedures and solutions. This way, potential owners would not be faced with the daunting prospect of having to do a lot of research and build a ‘team’ of experts and a knowledge base all on their own.
Matt
HI Martin,
Electrical Main size 100 Amps
Living space 753 sq feet (It’s a small appartment.)
60Amps required 40 Amps spare.
We have gas heating and water and no Air Con which migh explain the apparent large spare capacity.
If Tesla ever comes to Australia you will be on my list for my first\next electric car.
P.S Australia runs on 240 V for everything, not sure if this affects the calculations in your spread sheet.
Dear Editor, Based of PG&E’s rate of 0.16 per kwh how much will it cost to charge a Tesla per mile when the efficiency of the charging unit and the efficiency of the battery to take a charge are taken into account. Also note residential rates look they are going to raised 6% from here.
Would you please advise the minimum power requirement needed for charging the vehicle.
Editor’s response: Technically, the Tesla Roadster can be charged off of just about any 110-volt or 220-volt electrical socket in the United States using the optional mobile charging kit. The Home Charging Station can be configured to work with relatively small circuits – less than 20A – but charging times will increase as a result.
# ian s. wrote on September 14th, 2007 at 7:15 am
## one alternative that i have not seen discussed is that the charging station can actually take a charge itself, perhaps using an almost identical battery pack as in the car.
This idea has been brought up in the blogs before, but Tesla hasn’t had anything to say about it, at least not publicly.
# Jim wrote on September 14th, 2007 at 1:34 pm
## is there a Tesla pickup truck in development?
This has also been asked about. As far as I know, Tesla had never expressed any interested in doing a pickup.
Phoenix is doing electric trucks, but it seems they are concentrating on fleets, and may only offer a small number to private customers located near their offices in California.
www.phoenixmotorcars.com/
Service: 100 A @ 240V
Total required ampacity: 67A
Available ampacity: 33A
A couple of comments:
- You might want to clarify whether two joined main breakers labeled “100A” should be input as “100″ in your spreadsheet or “200″. I’m presuming that you want “100″ (ie. the feed is assumed to be 240V). If not, disregard the above numbers, and I’ll repost.
- I’m seriously looking into solar panels to provide some/all of my house power. Unfortunately (for me), from what I’ve read, LADWP was exempted from having to do annualized “net metering”, so instead they only do _daily_ net metering (in other words, if I want to keep my usage from LADWP at 0, I can only use as much power during the night as I’ve fed back into the grid FOR THAT DAY - sheesh!). With that in mind, I think environmentally-conscious LA owners will need a means to limit current drawn for recharging to a quite low amount (ideally, it should be tied to the amount of surplus electricity “given back” to the grid in the past 12 or 24 hours, but that may be difficult to obtain). Of course, this also means that I’ll likely be plugging in almost every night, to “top off”. Hopefully this type of usage won’t adversely affect the useful mileage-life of the batteries.
To answer Martin’s two questions posed above:
1) My house cannot support a 70-amp charge without upgrades. Therefore I’d want/need a lower-amperage (more flexible) charging unit for my garage.
2) Yes, by all means, you should create a “time of use” option (that included an internal clock) for the charging unit that guarantees a lower charge rate during the daytime (when we might be using most of your house’s load), but still allows a decent charge rate at night? Of course, in my case, since I’d be generating excess electricity during the day, I’d want the higher charge during the daytime, and lower at night. Go figure…
Best of luck, and I’m anxiously awaiting the release of specs. for the White Star (and desperately hoping, at 6′5″, I can fit into it, unlike the Roadster).
Martin,
To complicate things even further, you need to factor in the possibility that the house is powered by a grid tie PV system (NEC 690) which must obey to a very captious bus-overrating mambo jumbo (690.64(B)2) where the total of the grid feed and the PV feed cannot exceed the 120% of the busbar rating (residential) and 100% for commercial. Therefore, in most cases you need to downgrade a MAIN breaker from (let’s say) 200amp to 150amp as the remainder will come from the PV system.
Paolo.
> TEG2 wrote on September 13th, 2007 at 4:43 am
Since this is off-topic, I wanted to reply at teslamotorsclub, but it seems that site has been overcome with porn spam and abandoned.
Before coming to the USA, I had no idea that people living in the city used gas as a household fuel. It seems very dangerous to have open flames inside a house made of wood and paper (instead of brick and cement as I was used to). Every year in Minnesota there are about five cases of exploding homes, or people dying of carbon monoxide poisoning that make it onto the news. Who knows how many more gas related fires go unreported.
I wanted to switch to all-electric for years now, and the opportunity finally came last year when my A/C broke down. I replaced the A/C and gas furnace with a Hydron-Module ground source heat pump, the gas water heater with a Marathon unit and the gas stove with a Sears induction cooktop. I already had an electric clothes dryer.
This gave me higher energy efficiency, greater convenience, and of course, safety:
Heat pump:
Efficiency: Measured COP gt 3.0 in February, better in warmer months. (Old furnace COP was 0.8)
Convenience: Less maintenance than gas furnace and outdoor compressor.
Safety: Zero risk of gas explosion or CO poisoning.
Water heater:
Efficiency: Published EF = 0.93, measured EF = 0.98. Compare to best gas heaters at 0.86. (Old heater was 0.64)
Convenience: No more loud popping noises as water heats up. No more birds getting trapped inside the chimney.
Safety: Zero risk of gas explosion or CO poisoning. No more birds getting trapped inside the chimney.
Induction cooktop:
Efficiency: It cooks the food, not the house, therefore less heat to be removed in summer. Typical EF around 0.84 compared to gas at 0.4.
Convenience: Much faster and more controlled cooking. Less heat in the kitchen.
Safety: Zero risk of gas explosion or CO poisoning. Zero risk of rags or paper towels left too close to the stove catching on fire.
To paraphrase Martin: To hell with gas!
# J in MN wrote on September 17th, 2007 at 12:18 pm
## Before coming to the USA, I had no idea that people living in the city used gas as a household fuel.
## It seems very dangerous to have open flames inside a house made of wood and paper.
Yes, I can see your point. Thank you for commenting.
My wife swears that gas cooktop is the only way to go for having control over the heat, and being able to see just how much heat you are using on the food.
Gas dryers seem to dry the clothes more quickly and with (somewhat) less static on synthetic materials.
With my limited 100AMP service, I probably wouldn’t have enough left over for an EV charger if I had all electric appliances.
On the other hand, Silicon Valley is earthquake prone, and earthquakes can cause gas leaks, so we are “living on the edge” so to speak.
While with the Tesla roadster home charging will be sufficient I would suggest that with Whitestar you will need an option of on board charging to extend range. Can I suggest you invetigate the use of the Freedom Motors compond Wankel engine, (see www.moller.com/files/Rotapac_Power_Module.pdf ). This engine has a theoretical efficiency as good as a diesel, and is extremely light and compact. It also has the advantage that it runs very cleanly on ethanol, and particularly so when the ethanol has around 20% water content. This is important as removing water to get pure ethanol is expensive and energy consuming.
A Whitestar with an on board charging runnning on ethanol/water will completely preserve your “green” credentials, and allow Tesla owners continued independence from imported oil.
While it will be a few weeks before I can do the spreadsheet calculations, I would like to give this quick info. I have a 200 amp main feeder breaker for the house. For an electric car, I will use an existing installed & unused circuit that was original installed for an outdoor heated spa. Which, is an 220v, 50 amp hook up with its own circuit breaker panel, but still off the main house feed. The actual available free amps may not be 50 amps though. I am certainly planing to purchase an EV comparable to the class as my Honda Civic when such is available. I will also look into Solar Panels to supplement the charging (the need for the charger to have the option for such) . Me and my wife work a midnight shift, so any EV’s we are to purchase would have to be charged during the peak hours, conversely, because we are sleeping the only appliance being used during the peak hours is the house AC.
Required 174A
Available 26A
I have an all electric house. I won’t get away with 220.60 automatically. I have energy storage heaters so I’m already pulling (up to) 13 KW in the middle of the night in the winter for heating the house. So if I’m cleaning the oven at night and the hot tub heater and hot water heater kick in, I am actually fairly close to that 174A number… Now if the charger doesn’t mind losing it’s power until the storage heaters have gotten their fill, it could be connected to a load management system relay and everything would be fine… (In other words, a battery backup on the clock and settings on the charger would be a good feature. Even better would be a control wire interface of some sort.)
Efficiency is the fastest, cheapest and lowers environmental impact is available right now. We have a cultural problem of waste in this country that is unsustainalble. It has been a disaster for every level from obese bodies to obese vehicles to obese houses to obese debt. This culture is ruining our health, the environment, our finances and our standing in the world. Thirty five mile per gallon cars, twenty five mile per gallon suvs are available right now. We own a RAV 4 and when you stick 4 average American adults in it and lugage it not only becomes ustable, but sucks gas and is underpowered.
I wonder how the Tesla will do with two adults that weigh 225 (mid day weight with clothes on) versus two people that weigh 175. I'’ve been in many situations where the passenger load for four people was 900 lbs. I know a significant number of people would have a problem just getting in and out of a Tesla just as they do with many cars now. With electric vehicles being weight sensative this will be a large factor here.
Our problems are as much cultural as technical.
J in MN wrote :
“Since this is off-topic, I wanted to reply at teslamotorsclub, but it seems that site has been overcome with porn spam and abandoned.”
The Tesla Motors Club has moved to it’s sister site here: www.electricperformance.com/
I am running the same gas VS Electric household numbers as I consider a very large PV/Wind system. For cooking there is no question. Ask any chef and you will find that gas is clearly the way to go.
Also I would worry just as much about an electrical fire as I would a being gassed or in a gas explosion. I’d bet the Fire Dept. would say they see more of the former.
required amps: 55
available amps: 145
note: this data is from my parents’ house, 2,873 square feet built in 1992 in Ventura, CA. It was supposed to be “a/c ready” when built but they never installed a/c, and they have gas appliances and water heater, maybe that explains the large available capacity.
I live on a boat so I can’t provide any numbers from my place of residence
. However, I would love to see you modify your motor for use on a boat. I would be interested in a Tesla car, except I have no residential electric service to plug into. I DO know that we have a 20 amp shore power outlet at our dock box. We never use it because everything on our sailboat runs off DC power supplied by solar panels. Our (1973 Palmer gasoline) boat engine is currently in need of replacement and we would be very interested in an electric powered engine because we could recharge it from solar panels while cruising. I think many other boat owners in our marina would be interested too. Many older boats similar to ours are getting to the point where the engine needs replaced. This is expensive but many people are willing to do it given that production model boats used to be built much sturdier than they are now, so getting a comparably built new boat would cost twenty times as much as buying an old one and replacing the motor (replacement with a rebuilt 30hp diesel estimated at approx $10000 for my 30′ sailboat, with me doing the work myself). The only hurdle I can foresee is the necessity of making everything durable enough to withstand a corrosive marine environment.
I can’t directly answer the original question, which I suggest you ask at an electrician’s forums, like Mike Holt or Electrical Contractor Network. They know the NEC and every loophole.
What I can add is some information which I think Tesla could be interested in:
The amount of power available in a domestic service varies between countries. This also leads to limitations in different parts of the system, depending on how the system is laid out.
As you already know: In North America a typical service is center tapped single phase: 120/240V at 100 or 200A. This gives you 24 kVA or 48 kVA maximum, minus the 80% rule. Martin has already laid this out above.
In Europe a typical service is either single phase 230V (UK, Ireland, France etc.) at 40 - 100 A or three phase at 230/400V (Germany, Denmark, Sweden etc.) at 25 - 63 A per phase. There is no 80% rule and usually nothing in the rules to prevent you from loading this to 100%. Actual measured load. This means the power available at the house is typically anywhere from 9 to 45 kVA. (Smaller services do exist but any customer who can afford the Tesla Roadster is unlikely to have a very small service.)
Some countries (e.g. Israel) make the smaller services single phase and all larger (25 A and up) three phase.
As the alert reader may already have figured out is that homes with the power split over three phases imposes a severe limit on the charging of the Tesla Roadster: With a charging voltage of 220-240V it needs to be connected phase-neutral. This means you can only use one phase. This in turn limits you to 25 - 63 A at 230V which equals 6 - 14 kVA.
In Japan, power is supplied at 100V only service in many locations, with 200V also available in more recent homes. Similar to the North American system, but also available as a centre tapped delta. (A three phase system with 100 V neutral to phase and 200 V phase to phase.) The amount of power available is quite limited.
It is possible to design a simple and inexpensive system that allows the vechicle to work in all countries, optimised for the available power and meeting all safety requirements. Should Tesla be interested in this, send me an e-mail.
Dear Editor, What is the power input required by the charger to fully charge the Tesla and the range on that charge? What I want to know is the cost per mile in kilowatts after takeing charger and battery inefficiency into account.
Editor’s response: The Home Charging Station should be connected to a 70A circuit to get the fastest charge. However, the unit can be configured to accept a smaller circuit, as low as 20A. I hope that answers your question.
I’ve tried several DNServers, but this URL does not resolve.
I have yet to meet or hear of anyone who actually tried induction and did not agree that it is better than gas. Like so many other things, the inferior/conventional/familiar technology is perpetuated, because people simply don’t want to be bothered with trying the superior/new/unfamiliar technology. (Not that induction is new - it’s been around for decades in Europe and Africa.)
You should consider starting another “Tesla-like” company in the Southern California area.
> Roger Anderson wrote on September 15th, 2007 at 12:33 pm
while i don’t know if jumping into this is as easy as suggested, i totally agree that this is an excellent sister application of the technology tesla is developing. many new sailboats are being constructed right now with hybrid systems (larger than typical genset also charges battery pack that powers silent, clean, efficient, and more controllable electric motor driven prop(s). it’s clear that this is the future of sail-boating (and eventually powerboating), and retrofitting (or providing kits for) existing boats with aging diesels is a significant, untapped market. as roger anderson mentioned, most sailboats are already conveniently wired with an existing electrical system which typically includes an a/c shorepower hook-up, so this application is that much less challenging.
interestingingly, i have not seen any of the new hybrid designs substitute the traditional lead ballast in sailboat keels with an active battery pack. i imagine the weights are similar, and while this location would be more difficult to access and require a more vertical battery pack design, it doubles the utility of the weight of the ballast necessary in a sailboat’s keel.
required amps: 109
available amps: -9
Los Angeles/Ventura area
1600 sq ft, no garage
Well pump, pressure pump, air conditioner, and hot tub pump all have potential of kicking on at night.
Had SCE out today….
it’s good to see that full size cars will soon be on the streets more often. i have had been into racing electric powered 1/10 model cars int the past and have always imagined how it would be a great idea to make a full size car into electric. i guess i was one of those only kept the thought in my mind only and did nothing about it. well now i have the opportunity to type something about it :
i’m pretty sure there are millions of ideas to improve the capacity and charging methods of tesla cars i still want to add a few more: front tires can be loaded with hub style dynamos to produce electric to recharge the batteries on the fly, front air intake can be equipped with a dynamo-fan system that would generate enough current to recharge batteries via wind power, solar panel can be embeded into the hardtop of the car for maximum exposure to the sunlight to generate extra energy for recharging batteries, couple of Faraday’s Magnetic Field Induction coil can be installed into the various locations of the chasis to generate energy from the momentum of the car, (also this can be applied to inside of the wheels if there can be a way to do it without unbalancing the wheel), main shaft of the electric motor can be used as an armature of the dynamo to produce current from the motion of the original motor thus causing instant recycling of the energy, battery housing can be cooled via a radiator system that runs with a coolant liquid in it to ensure certain level of temperature constantly cools of the batteries. since electric powered vehicles are made to save our planet i’m willing to produce more ideas about them in the near future and i hope everybody will be able to read all of this thanks.
Total required ampacity for 240V 1-phase Main Electrical Service 173 A
Available ampacity in Main Electrical Service 27 A
Clas-Henrik Gustafsson wrote on September 20
I imagine the most difficult part would be to meet all the various electrical codes and safety requirements, not because they would be hard, just different. It is trivial to substitute the full wave single phase bridge rectifier with a 3 phase version, so that part of it would be easy.
Martin,
This is off topic, and may be considered Blasphemous, but how about an agreement with Chrysler or somebody to build a midsize 5 passenger sedan in which you then install the EV components. Could we not be driving EV’s alot sooner that way?
Dear Editor, My question related not to the amps and voltage required for the charger, but to the actual power draw in watts that the charger consumes to charge the Tesla and how far it will travel on this charge. This will give the readers an idea of the efficiency of the charging operation through the charger and the efficiency of the batteries at taking the charge. I know these figures can vary depending on the charger, the speed of the charge and discharge rate. This is why I suggested a mix of battery types and maybe a capacitor in the mix. Do you have any views or comments on the firefly battery that is coming out soon. It’s set to apear on a Husqavarna product this year. It seams this would offer a low cost alternative until better low cost batteries come to market. Thank You
Availabe: 200A
Required Ampacity: 162A
Availabe Ampacity: 38A
I have an all electric home but as previously stated; the Roadster can be charged at night when few - if any - appliances are running (save the A/C which we need here in FL).
Hi, Sorry to complain but white text on black background might look nice but it is almost impossible to read!
Otherwise thank god you are doing what you are doing!
Regards
BIll
I am now living in Hong Kong, but when I lived along the Gulf Coast of Texas, my home and many others, especially ones built before central AC became common, have a separate breaker for the AC. This was because the AC was added on as multiple window units. When I bought my house in 1982 the wiring was in place but there wereno longer any window units since the furnace was converted to AC. The separate breaker for the original window units was 220-240 volt/70 A. I ended up removing the old wiring and installing new outlets in the garage to power things like welders and air compressors. Even so, there would have been ample capacity for charging an electric vehicle. Most new homes in Texas have the capacity built into their electical system to handle 200 or more amps. Most of the large electric consuming devices are running on 220-240V (ovens, stoves, some washers and all electric dryers). These are typically the items that draw the most current. With the way the NEC is designed most all newer homes have more capacity built in then they will ever use. If you are charging at night, most everything that draws or has a high current load is off with the exception of AC and in some cases these are actually on an entirely separate circuit from the rest of the appliances (directly off the main).
it may be necessary to require blog posters to state newton’s law of conservation of energy prior to posting.
A charger question regarding V2G: Does the Roadster support Vehicle to Grid (V2G) operation whereby during a power outage my EV can be used to power my house (assuming it’s plugged in). My understanding is that Tesla is using some key technology from AC Propulsion. I believe this includes the inverter and some key pieces of the charger?? I’ve read that the AC Propulsion technology does support V2G (read: www.acpropulsion.com/technology/Veh_grid_power.htm) and wonder if this capability is part of the technology licensed.
Thanks, Harley Dave
Editor’s response: The Tesla Roadster does not currently support V2G, but we are working on the technology. See our recent press release.
Green energy: Solar’s Big Boom:
www.mercurynews.com/ci_7001523
This sounds like a perfect application for dabbledb.com or docs.google.com (spreadsheet).
]{evin
Total required ampacity, 126 A
Available ampacity, 74 A
A 1,700 sq. ft. house in Modesto, CA
Electricity provided by Modesto Irrigation District - yes, it’s farm country.
The main breaker is 200 amp, but the total for all the branch circuits is 460 amps! Good thing we never have everything on at once. There is 240 volt circuits for range, dryer, and AC, and a 240 volt 30 amp circuit that isn’t connected to anything - I’ve checked, it’s off and everything runs.
I have the technical skills and space in the main panel to wire in a 240 volt 70 amp circuit for an EV charger, now all I need is a lot more money to buy a Tesla. Penny pinching time! Hey, maybe the whitestar sedan will be ready when I am…
What do you think about a ‘comfort turn signal’? You tap once and it blinks three times. This is a very nice feature for changing the lane or leaving a roundabout. I build this feature since 3 years. More and more people from the US ordered the B3 module. You can test it for free if you want. Perhaps you can integrate this nice idea into your great car. I love the Tesla Roadster.
Thanks, Andreas Ziegenhirt
the portable power unit that i have might be able to run your charger just need to know more abought it
i will start showing the unit this weekend and building them after that if all goes right i can step it up more to handle the charger
Also to continue the discussion of ‘house is powered by a grid tie PV system,’ [690.64] would be options of either the load (opposite) side or supply side point of connection …
Dear Editor,
How many watts input to the charger does it take to charge the Tesla and how far will it currently go on this charge? Does the efficiency of the charging vary with the speed of the charge and the initial charge level of the batteries? Do you have any comments or views on the Firefly batteris that look to be very low cost and would probably be very cost effective although at some sacrafice? Thank you.
Randomness:
Watched “Living with Ed” recently where he visits Larry Hagman’s beautiful home.
He shows off a huge solar array and mentions that he has 81kW (!) of solar generation.
www.ojaisolar.com/in_progress.html
Noticed that Ed and Larry are on the board of “SELF” along with Freeman Dyson who is a famous cohort of Richard P. Feynman…
www.self.org/what_board.asp
adsabs.harvard.edu/abs/1974PhRvD..10.3978C
www.teslamotors.com/blog4/?p=56
Martin,
Why not dedicate two panels to your charging system? 1 for AC power and another for DC power. The current NEC code has little to zilch language on the limitations of DC systems and a company like yours could help set the stage for the NEC verbage of how to integrate electric car charging into residential and commercial applications.
Although i wish to see your electrical system for the roadster I can make the assumption that the core of your power supply is DC. WHY LOSE POWER IN AC TO DC TRANSLATION, KEEP IT AT DC. Electric car charging should be handled in an DC method.
The main reason I’m writing is to advocate an International Design Competition geared at Architects and Engineers to design your company’s most perfect R + D facilities now and into the next “gears” of Tesla. Thank you for reading.
Kyle Schertzing
University of Michigan TCAUP 05″
Editor’s Answer: Direct from Martin
We are with Nikola Tesla on this issue. The trouble with DC (as Tom Edison quickly discovered) is that it is impossible or at best horribly inefficient to change the voltage of a DC source without converting to AC along the way. Thus, if your solar panels are producing 250 volts at the moment, then you simply can’t charge a 400-volt battery. If your panels are producing 600 volts, then you will lose 33% of the energy dropping down to charge a 400 volt battery. The efficient way to switch DC from one voltage to another is with an inverter - an inverter converts the DC to AC, puts it through a transformer(or equivalent) to step the voltage up or down with surprisingly good efficiency, then rectifies the AC back to DC at the desired output voltage.
Inverters are getting pretty darned efficient. The inverter in a Roadster is around 90% efficient (While charging, this inverter rectifies the AC charging voltage. While driving, it converts the DC from the battery into AC for the motor - or the other way around for regen); the inverter on my solar panel array (which makes AC out of the DC from the solar panels) is maybe better than that. This system works over a very wide range of voltage from the panels and also over a wide range of voltage in the battery.
Counter-intuitively, passing through AC is about the most efficient way to charge a DC battery from a DC solar panel array.
Best, Martin
I Live in the UK and have been reading these blogs for a while now and there seems to be a lot of bull written about charging EV vehicles.
Most houses should be capable of supporting an 8-10kw load overnight as many loads reach this figure for short periods when heaters and cookers are used at the same time.
The US still seem to stick with their antiquated and inefficient 110vac house distribution. The rest of the world are on 220vac which allows for a larger load to be used for the same size of supply cable.
It stands to reason that any roll out of electrically powered vehicles will see the introduction of intelligent chargers which will draw a variable current from the mains supply as and when it is allowed to by a web link to the supply authority.
They will be happy as the power stations which are presently running at reduced capacity at night, which is also inefficient, will be then run at peak efficiency and they will also profit from this scenario.
Here in the UK our electricity is at much lower cost at nighttime so many such as myself use the built in timers on dishwashers and washing machines etc. to save money.
Too much negative energy man! To paraphrase that line from “Hogans Heroes”.
I hope Tesla do well. I am building my own Lotus Elise powered car so we will se who is on the road first!!!
Russ
Charger Standards. Editor: Thanks for responding regarding V2G. It looks like PG&E is not yet talking about bidirectional, but allowing them to control chargers (I presume over the Internet?) will be helpful—and probably required—to avoid brownouts, especially in CA. I’m hoping bidirectional is on the roadmap.
But this raises another charger issue: standards. I assume the onboard 120v charger uses a standard 120v plug, but from the pictures I’ve seen, the 240v charger uses a special adapter. And interfacing with electric utilities like PG&E for sophisticated control of charging adds a significant new communications layer to something that should become a standard.
My interest in electric vehicles in general and Tesla specifically stems from my broader interest in the establishment of an overall electric economy (if I may be so bold, I’m putting together a blog for like-minded individuals: www.geopoliticsofenergy.dyndns.biz). During my research I was fortunate to find Tesla early on in its published life. In addition to becoming an important proof-point for the establishment of an electric economy, Tesla has taken the concept of electric cars to a very exciting place, whether we are able to clean up our energy act or not. But to have a market you must have more than one player, so I’m glad to see a few potential competitors making an appearance. Ironically, I believe for Tesla to reach their full potential as a business they need successful competitors that will need to share charging infrastructure.
Any work you can point to on the charger standards front?
Thanks, Harley Dave
During the “Living with Ed” show, GM was showing a rather surreal / bizarre commercial for the Volt:
www.youtube.com/watch?v=R_J2Jx51XZs
# TEG2 wrote on October 3rd, 2007 at 1:08 pm
# During the “Living with Ed” show, GM was showing a rather surreal / bizarre commercial for the Volt:
# www.youtube.com/watch?v=R_J2Jx51XZs
[Announcer] And you can get up to 40 miles without burning a drop of gas.
[Children] Wow!
sigh.
Sorry I know this is the wrong place to ask a question but I don’t see any email address in the contact us link so here is my question. have you guys at Tesla ever think about using magnetic motors to produce electricity ??? I saw some videos on youtube that show these motor running on nothing but free energy.
thanks
Martin,
Here is what you do.
Design the charging circuit to work with the minimum available power permitted by the NEC, this is 180 VA for a general purpose wall outlet @120V. Everyone has a general purpose outlet in there garage!
1) Assume that the minimum available power at the outlet is 1.5 Amp/hour @120V as a minimum.
2) Depending how fast Tesla would allow the battery pack to fully recharged. Provide the custormer with the required amps needed at the outlet for this to happen. The customer will then decide if he needs to upgrade his circuit.
The minimum reserved VA (Volt Amp) for a general purpose outlet permitted by the NEC is 180 VA. @ 120V this gives you 1.5 Amp available at the outlet.
# Onisem Gomez wrote
# The minimum reserved VA (Volt Amp) for a general purpose outlet permitted by the NEC is 180 VA. @ 120V this gives you 1.5 Amp available at the outlet.
As I understand it, the advantage of trickle charging is that it generates less heat and reduces energy consumption by the battery’s own cooling system during charging. So although the battery only stores 53 kWh, charging it up in 3.5 hours (the maximum rate) requires 70 kWh in total when cooling demands are factored in.
However, a full charge from “empty” using 120 V and 1.5 Amps would be extremely slow (about 294 hours - that’s over 12 days continuous charging - to reach 53 kWh).
This is ideal if you’ve left the Roadster in the Airport long-stay car park, (some ESS cooling might be needed to deal with daytime temperatures) but otherise it would really be “Sunday motoring only” - six days to reach 50% followed by one day of 100-120 miles of driving.
A useful charging interval seems to be the Electrical Energy Supplier’s Off Peak period - at present from midnight to 7 am. If daily motoring needs only require 100-120 miles then a 50% charge could be achieved in this 7 hours with 220 V and 23 Amps (assuming that 7 hours charging consumes 8.5 kWh for cooling). That would give a total of 35 kWh of AC needed.
What’s not clear is if the Tesla Home Charging System (or the car) allows the user to select lower charging current rates rather than just the overall required battery capacity target.
However, anyone who has an Available Ampacity figure as low as 25 Amps (assuming 220 V) is by no means out of the running. Okay, installing a Tesla Home Charger is a bit pointless (assuming that the Mobile Charger can handle up to 30 Amps - is that true?) and they’d have to build up a full charge over a number of days of more sedate motoring, but they’d also waste less energy cooling the ESS whilst charging.
In fact, given the better urban mileage due to lower average speeds and more effective use of regen, it may prove to be very easy to build up the battery’s charge while commuting during the week, and thereby only require a low current top-up for greater range (if required) on Saturdays and Sundays.
Martin - I’m sure you’re ahead on this, but it strikes me that, now that the Roadster’s range values are confirmed, this Electrical Survey needs a corresponding Mileage Survey - split Mondays to Fridays (commuting) and weekends (leisure motoring)? Averaged over a month? With a breakdown of Urban vs Highway vs Interstate mileage and typical speeds? A spreadsheet could give a breakdown of AC energy required for ESS storage and ESS cooling for different charging currents and charging durations, as well as total electricity costs which would be incurred during different tarrifs and consequent costs per mile? Would be great for potential customers to be able to type in their present mileage and average speeds and compare their monthly maximum / minimum EV electricity bills with their present expenditure on gas. I’m sure that many people will be shocked to see a two seater sports car cost less to “fuel” than their present vehicle. More useful data for Whitestar and Bluestar as well.
A Mileage Suvey has another key benefit; customers who lack the available ampacity to run the Home Charger at full tilt, may discover that they do not need to. And even those who can, may prefer not to for most of the time - both to save money and reduce waste heat generation.
Required Amps: 290
Available Amps: 110
My 400A panel has a 200A breaker for the main circuits and a 200A breaker for a subpanel. But the subpanel is now limited to 60A because I wired my solar inverter / backup system into it. So, I may still have some electrical code trouble upsizing an unused 40A EV charging charging circuit to 90A on the main 200A breaker, but worse comes to worst I can have the two 30A 240V dryer circuits removed, since they aren’t being used.
The tougher challenge is finding additional South-facing area for another 2 kW of PV to offset 50 miles/day in Tesla driving. Most of my roof is either shaded or facing East/North, and I’ve already maxed out the vacant lot with an existing 5 KW array.
My hard question is how will this vehicle work in the harsh northern climates where we get snow and ice and week long temps of minus forty .Im very interested in purchasing but i need those questions answered.Also i have a generator which isnt on the grid which would work fine for the recharge purposes .Halibut is a nice fish but i prefer haddock .
Jamie, you may be interested in this blog entry, www.teslamotors.com/blog4/?p=55.
Dear Editor,
Is there any chance in the future that a lower cost tesla could be equiped with the Firefly batteries that are coming out next year. Wouldn’t this save not only on the batteries, but also on the battery management system?
I wonder if the technicians at Tesla Motors have looked into Nano Titanate batteries. From what I read they are far superior to lithium Ion and would be a huge advantage to the Tesla Roadster especially in public acceptance in terms of recharge time, safety and life expectancy.
Arthur W. Hanson: Firefly batteries are interesting, but it’s unlikely to replace Telsa’s Lithium Ion choice until they’ve proven themselves for a few years.
Grant: If Tesla used “Nano Titanate” batteries, the car would cost $300,000. That’s why nobody is actually selling cars with them.
Now that there is electrical survey which is directly useful for Tesla I suggest this for some future blog entry:
Survey: which practical sedan _looks_ coolest for you.
That is to aid Whitestar designers to create cool, but still practical exterior for a car (it isn’t too late, is it?).
My vote goes to Honda Civic type R 2007/2008 model. That is actually hatchback, but I’m not quite sure how “sedan” could be defined. Anyway, I like it.
Question about batteries:
This question raised up in my university lunch break (where I was furiously defending electric cars over gasoline cars
): What is Tesla ESS charging curve? I believe it is not linear, so how much energy would I get if I charge near empty battery for only one hour, instead of 3.5?
250 miles is about 3/5 of the range I need to get to my (other) home from my work, so I would need only one place to charge it in between. But how long I need charge it to get that missing ~150 miles.
Timo: Since the Tesla ESS is built up out of the same kind of cells as a laptop computer, my guess is it follows the exact same charge curve. If that’s true, it’s a fairly linear charge rate up until 85% or so, then it slows down.
If the Tesla ESS takes 3.5 hours for ~230 miles of highway range, you get a little over 1 mile per minute of charge, so maybe 2.5 hours to get 150 miles plus extra for safety. Note that you need 240volts/70amps to get the fastest charge rate, which could be a problem until Tesla-compatible charging stations are easier to find.
This is not a commint but a question. I could not find a place on this website to ask. Is there a way to obtain the the chassis modifications, electrical and electronics to change my project truck into a Tesla powered vehicle? I don’t need 0-60 in 4 seconds or 140mph but would like some performance…This would be an awesome upgrade for my old truck. I have the truck stripped to the frame just waiting. I would use carbon fiber or fiberglass body parts and by removing the motor, and axels weight shouldn’t be to big a problem. I heard Tesla Motors licensed their technology to an over seas company, so I was hoping I could obtain the necessary parts for this projects from Tesla. Thank you fpr your time.
Michael
# Timo wrote on October 11th, 2007 at 12:57 pm
## Survey: which practical sedan _looks_ coolest for you.
## That is to aid Whitestar designers to create cool, but still practical exterior for a car (it isn’t too late, is it?).
Teslamotorsclub is back up! Check this out:
www.teslamotorsclub.com/showthread.php?t=312
## My vote goes to Honda Civic type R 2007/2008 model.
Also, take a look at this:
www.teslamotorsclub.com/showthread.php?t=566
# Ryan Lamansky / Kardax wrote on October 11th, 2007 at 3:18 pm
# Timo: Since the Tesla ESS is built up out of the same kind of cells as
# a laptop computer, my guess is it follows the exact same charge curve.
# If that’s true, it’s a fairly linear charge rate up until 85% or so, then it slows down.
Which means that charging from empty to 85% is faster than charging from 25% to full. How much faster is the question. Do you have some link somewhere where those battery charging curves can be found?
# Note that you need 240volts/70amps to get the fastest charge rate, which
# could be a problem until Tesla-compatible charging stations are easier to find.
Well, I live in Europe in Finland, so for me this is still just theoretical. In here we have 230V system and for three phase you get quite a bit more. That means that amps don’t need to be that high. Of course Telsa doesn’t have any chargers designed for European currents, so it still needs to designed before this is possible.
Anyway, I’m quessing that if you make it compatible to basic european three-phase connector I can get some gas-station to serve me just by phoning them. They would probably let me charge my Roadster/Whitestar just out of curiosity. I would of course pay that ~5 euros for that service
# TEG2 wrote on October 11th, 2007 at 11:55 pm
## Timo wrote on October 11th, 2007 at 12:57 pm
### Survey: which practical sedan _looks_ coolest for you.
### My vote goes to Honda Civic type R 2007/2008 model.
## Also, take a look at this:
## www.teslamotorsclub.com/showthread.php?t=566
There’s that Honda Civic
. Something appealing in its bullet-like shape. I bet it has quite low Drag Coefficient., which would be nice for Whitestar. And practical, especially four-door version of it.
Martin, I sure wish I could put my statistics degree to work on your Excel Spreadsheet, but most of my generation doesn’t own a 2 car garage or even home for that matter… In fact, most of the human beings on planet Earth don’t own homes or can plug in… I sure wish there was a cheap electric car that could run on solar panels that were part of the body of the car or something… I’m worried that the projections from 800 million vehicles currently to 1.2 billion in the near term and 2.5 billion around 2030 play out only to increase demand for cars that don’t require homes and special Hyatt chargers… It would be great if your next car could serve mankind somehow… Maybe a universal plug compatible with any plug anywhere around the world…
If transportation is responsible for 1/3 of smog today and the fleet of cars and trucks triples tomorrow, how will mankind survive (assuming that the fleet expansion ratio is the same as it is in China right now = 99% cheap internal combustion engines)? I wish you luck in attacking the auto industry’s 60 million per year output and cheers for reducing smog.
Interesting note, China has gone from 40,000 electric bikes in 1998 to 25,000,000 today, with 40,000,000 projected by 2010, Almost all use lead acid batteries weighing about fifty pounds and have a thirty mile range and go through four batteries in their life span. China is also building numerous electric cars. Many cities have banned gas scooters in the central cities.
Energy Storage Technology Advancement Act of 2007 (Introduced in House)
www.thomas.gov/cgi-bin/query/z?c110:H.R.3776:
As well as the TEG, there may be some opportunities for the Tesla 16kW public charging stations.
George Clooney to join the board of a Swiss clean-tech firm:
www.foxnews.com/story/0,2933,303821,00.html
Required: 129
Available: 71
I still like the idea of exclusive load sharing 50A, 240V device as a less expensive charger option to installing a dedicated 70A circuit or worse upgrading one’s panel too. Not a big deal for the $98K Roadster, but would be more viable for the $60K sedan.
Please read this: the blogs are getting hit by a spam storm. If your post contains more than one URL, it is likely to get thrown into the spam bucket. Due to the high number of spam comments, I may miss it. Think before you post
The Editor.
Available ampacity 231A
Required ampacity 169A
I guessed on the high side for loads that I wasn’t certain about - 400A service.
“Hybrid or All-Electric? Car Makers Take Sides” (WSJ article):
online.wsj.com/article/SB119316295232868647.html
“Honda Won’t Pursue Plug-in Hybrids” (WSJ article):
online.wsj.com/article/SB119313344275568239.html
The 7th International Conference on Materials for Lean Weight Vehicles
11th and 12th December 2007 at Warwick University in the UK
Anyone from Tesla or Lotus going?
www.lwv7.co.uk/programme26_07.html
Editor’s Answer: According to the schedule Lotus is presenting, so I expect they will be there
We have presented in the past, but not this year.
hybrids are an ignorance-induced stepping stone to all-electric since every auto lobbyist from 1973 forward has stamped out any congressional murmur about serious research investment in auto-specific battery technology. apparently some automakers feel (only 30 years later!) that they no longer need to prolong the excrutiating time and energy wasted on this intermediary (and cumbersone) makeshift technology. it’s refreshing to see some environmental common sense from the auto industry, even if it’s blatently profit driven. too bad it’s so furiously intermittent. the forecasted time span between traditional ice and all-electric must now be short enough that honda et. al. realize they’re wasting their money designing/building bloated hybrid clunkers. with auto batteries conquered, next will be the big trucks (and quiet city streets, can you imagine!!), boats and ships, and somewhere in there, grid-independent solar homes.
with respect to tesla, at the very least the company/car will forever be the iconic symbol of the first true successful transitionary vehicle (we hope!), with the ev1 as the sorry, misguided, trampled whiff. with the threat of the big manufacturers coming on strong, tesla has very cleverly positioned itself with a unique opportunity to take hold in the soon-to-be burgeoning and radically morphed auto industry. but only with persistent brilliance and guile (read: flawless product delivery and massive marketing effort ) will tesla be able to join the rank of the good ‘ol boys as a major manufacturer. the alternative, which is much more likely and certainly more prestigious than an exhausting fight with the goliaths, is to earn a seat with the elite exotics, continuously pushing the envelope and offering the fruits of cutting-edge technology to the masses. when formula1 is all-electric, and tesla has a team (and rocket chair), that’s a day to celebrate as the ev’s true coming of age!
~ian
Martin, looks like your talk at the Stanford Entrepreneurial Thought Leaders seminar was a big hit, both on the content and your presentation style:
etl-forums.stanford.edu/viewforum.php?id=25
Someone on the forum mentioned how smoothly and professionally you dealt with an obnoxious questioner after the seminar (handing him your business card and asking him to apply for a job!) Fantastic trick, gonna remember that one!
Wish the seminar video was available to non-Stanfordians. Oh well!
I know you folks have your hands full (to say it mildly), but I wanted to toss out the suggestion for a “Roadster Light” someday:
35kWH pack
One gear
90MPH top speed
170mile average range
2300lbs (2/3 ESS capacity and no transmission might get you there already)
$80,000
Well, that’s dissappointing:
Main Panel: 70A
Load Use: 54A
Available: 15A
But then, this is rented accommodation in Canada.
Incidentally, has any thought been given to problems with temperatures? In this part of the world, for 5 months a year, the temperature is around -30 to -40 (in F or C? First one, then the other), which has an extremely detrimental effect on batteries.
a company creating an electric car that ’s putting emphasis on environmental concerns and consumption/output would be producing an electric car at a price point (and production numbers) that is realistic for the many….not an exclusive niche vehicle
To M: Tesla’s working on it: www.teslamotors.com/blog2/?p=8
The basic plan is to establish a recognized brand and steady income with the Roadster, then work towards cheaper models.
Can you please see about this fellow inventor and provide him with council.
www.teslatech.info/ttmagazine/v4n4/pantone.htm
How do I become an investor in this company??? can someone let me know thanks…chris
Jay Leno puts 54kW PV on his garage…
www.popularmechanics.com/automotive/jay_leno_garage/4228638.html
Somebody commented on the possiblity of charging the Tesla Roadste using PV solar panels.
Well, this is off course a very efficient option. We at sol3g manufacture concentration photovoltaics, a new generation of solar systems. Please have a look at our S4000 product brochure:
www.sol3g.com/downloads/eng/S4000eng.pdf
I have made a simple spreadsheet using Tesla’s energy consumption data, the production capacity of our solar systems, and the average solar irradiation in Los Angeles and San Francisco. If you would use one of our S4000 systems, you would produce the energy necessary for 161 km/day in LA and for 130 km/day in SF. The price of the S4000 system is around 16.000 €, including civil work.
This way you would have a really complete green zero emissions transportation system.
Ricard Pardell
CEO
Sol3g
Third Generation Solar Systems
# www.lwv7.co.uk/programme26_07.html
# Editor’s Answer: According to the schedule Lotus is presenting, so I expect they will be there
# We have presented in the past, but not this year.
Doh! I missed the entry for Lotus Engineering!
My reason for asking was really in respect of the Whitestar development, but I appreciate that at the moment, you are all a tad busy
# Ricard Pardell wrote on November 10th, 2007 at 3:49 am
…quite interesting stuff about solar panels, with one error:
## www.sol3g.com/downloads/eng/S4000eng.pdf
That link is not working. Here is the right one: www.sol3g.com/downloads/eng/Sol3g_S4000_en.pdf
are you going to show the car at the houston car show?
I am trying to findout more information on the White Star sedan. I just learned about Nanosolar’s powersheet which I think might work on the roof of Tesla White Star to extend its range. Please have someone contact me about these issues.
I am seriously considering purchasing one of your products and I am planning on doing a heavy up to my electrical service for another project. I am curious as to the amps needed for the Power Station needed to fuel the cars. As long as I am changing the service I might as well plan for the car too so I don’t have to do it twice. I can not find any info about the Power Station and its electrical requirements. Can you please post them or a link to the info for me…… Thanks
Kevin Harney: Tesla hasn’t formally posted the requirements, but the consensus seems to be 240 volts and 70 amps. That’s for a 3.5 hour empty-to-full charge. It’ll work with less, but the charge will be slower.
Kevin Harney just posted a inspiriting post. What are the requirements for Power Station for single car. Combined to Ricard Pardells post about solar panels how much it would cost to put up one of those. I know Kevin is talking about his own “power station” and not something that could be used as “service station”, but lets extend this a bit.
Here is the question: If we put up an solar powered service station for Teslas what would it need? How much would it cost?
First of all: One S4000 solar panel (www.sol3g.com/downloads/eng/Sol3g_S4000_en.pdf) is enough for servicing one Tesla if we assume that it gets serviced every third day for full charge. Then we need batteries for storing excess energy for days it doesn’t serve Tesla. What is _cheapest_ battery tech that can store 53kWh of power if you count maintenance and replacement (if needed) in it. It doesn’t need to be small like car ESS.
16000€ one time cost for solar panel. Then there is battery for storing. Then maybe site rent for putting that up. Someone must keep that running so there is some salary cost too. Could that ever pay itself back? Does it have to?
If, lets say five, Tesla owners put that up in somewhere between some place they would like to get every now and then, but can’t because range is too limited, expenses could be divided between owners. 16000€ is about 22400$ / 5 = 4480$ for solar panel. That is very tolerable. How much about batteries (flywheels, whatever)? What about site rent? Tesla owners club anyone? Tesla itself? How about mapping the “hot spots” in the roads where two potential charging places are too far away form each other, and use some of the gained money to build up Tesla service stations where owners need it?
Have you ever considered giggle technology (my term) for recharging as you drive? By placing magnets on the struts/shocks and coils (or other places) you may be able to generate enough current to extend your range. There is a company M2E Power in Boise Idaho working on this technology for recharging cell phones as you walk (Seattle Times Business section Nov. 16).
Like what you are doing but need something closer to the Prius price to be a smash hit.
I think the Tesla Roadster is BEAUTIFUL and the technology is great, remarkable performance! But, why not make a car for the masses, say a sedan thats just as beautiful with 1/2 the engine power, which should make it go twice as far and charge up in the same amount of time and put the price 1/2 as much, say $45-50k? I think that would be a hit!
To Jim Altman,
You need to consider that any added wait detracts from overall performance. Now added that shock/strut to a person walking is pretty much ignored for the weight to motive power. But, adding that to a car that you are trying to keep weight down and provide more the a negligible power increase is a whole different matter.
# Kareem Watts wrote on November 18th, 2007 at 3:52 pm
## I think the Tesla Roadster is BEAUTIFUL and the technology is great,
## remarkable performance! But, why not make a car for the masses, say
## a sedan thats just as beautiful with 1/2 the engine power, which should
## make it go twice as far and charge up in the same amount of time and put
## the price 1/2 as much, say $45-50k? I think that would be a hit!
That is exactly what they are doing or, to be more precise, will be doing. see www.teslamotors.com/blog2/?p=8
This REALLY needs to be somewhere in forum FAQ with cat-size letters “READ THIS FIRST”.
Nothing wrong with your question Kareem, but this really has been asked about ten times now. Or more.
Editor: Is it possible to get another tab in blog-page that says “FAQ” and which just answers questions that raise here again and again and again?
Um, now that I read your comment again there is something worth correcting.
## But, why not make a car for the masses, say a sedan thats just as
## beautiful with 1/2 the engine power, which should make it go twice as far
With EV halving engine power doesn’t double the range, quite opposite. With bigger eMotor energy losses are smaller, so halving motor size would actually result smaller range, not bigger. You really can’t get it go much further than Roadster goes without increasing the ESS size, which is the costly part of the car. It has been estimated that ESS price is 20-30k$, which would leave half the price car 30-20k$ for the car itself. Only way to make it go twice as far without doubling the ESS is to halve the air drag and rolling resistances, and doing that would leave you with impractical car design. You _can_ lower those a bit, but not much.
I love what Tesla is doing in the auto industry. I wish there were a group of people just as committed to changing the way we build houses in this country.
House main is 200A, current usage 109A, availible 91A
I removed my current EV charge from this calculation which is currently 40A
Looks like you aren’t the only ones not able to attend the The 7th International Conference on Materials for Lean Weight Vehicles.
It’s been re-scheduled as a “Webinar”
www.lwv7.co.uk/
Martin
Thankyou for the Roadster
Best wishes to you, Carolyn and the kids.
Martin,
Thank you for the Roadster. Thank you for the vision of entering the top end of the market and driving downward. And thank you, most of all, for being the guy who will be remembered as the man who changed the world.
Best wishes to you and your family,
Mark Tomlinson
Good luck to Martin Eberhard. For most of us you will always be the face and conscience of Tesla Motors.
Will many of us now rethink our enthusiasm for the Whitestar. After all, there are several interesting sedan concepts out there.
Tod G. Collins, Orcas Island
Martin:
What happened??? Your name is no longer on the Company Team. I am sorry to see you go, I will always think of Tesla Motors as being your company.
I know you are self described as a start-up guy, and in the case of Tesla Motors you have done an amazing job. I wish you the best in what ever future endevours you get involved with. Here’s one that I would like to do, make conversion kits for tractor-trailer trucks. When this becomes a reality, all trucks will convert to be able to stay competitive with the lower energy costs of electricity vs diesel fuel. They will do it to save money, the world will benifit with lower pollution.
I know this may sound very simplistic, but here goes. Most American homes have 120v 60cycle AC current (with the exception of the laundry room where most of us have DC 220V). That being said, charging should be ‘golf cart-like’… heresy, I know. But when I was a kid all of the golf cart chargers required a 220V outlet. This was a big pain for people who owned and managed same. If adoption (i.e. market penetration) is the key to success, I’d make sure the American Market gets its charge from the plain-old household outlet (not that Barney Fife is going to be driving one of these rockets!) As for the range, I’m not too concerned that this will be a long haul car. This is an in-town runabout, show off car. As long as you can get the golf clubs in the car, the only range you need, practically, is to the club and to a restaurant where you can show off your compensatory acquisition to the girls.
The TESLA Sports is the way forward if we stop attempting to light the night sky (and the universe beyond) if we use the energy created at night to charge our EVs. I once had a TR8 with its 0-60 in 6 secs and and a gas mileage of about 15 mpg around town.
The idea of 0-60 in 4 secs and an equivalent gas mileage of 135 mpg is stupendous. We need to get Utilities to understand that the cheap night time energy wasted lighting empty streets on city blocks is adding to CO2 emissions, global warming and climate change. If we ALL had EVs that we charged at night then no long tailpipe but very unhappy Big Oil (?) unless they invest in hybrid and EV. Just common sense for a sustainable future to me? Sadly Big Oil want the big bucks now - we pay later.
# George Aubrey wrote on December 4th, 2007 at 8:36 am
## This is an in-town runabout, show off car. As long as you can get the golf clubs
## in the car, the only range you need, practically, is to the club and to a restaurant
## where you can show off your compensatory acquisition to the girls.
Hummer is a “compensatory acquisition”. Anybody that buys a nimble little sports car is buying himself a girlfriend.
or boyfriend.
I see in the FUTURE is people and their ideas , and their country , and their children will build global new economies by and for the people with there own ideas with a word FUTURE has a meaning to all .Can help all , in meny ways im like tesla , have ideas want to hlep all people all countries , and I Am a head of my time .and president /founder/solepriortor of www.futurevisionaries.com
I live in Nevada. Is it feasible to set up a solar collection array and instead of feeding the juice to Nevada Power, I could feed the juice to the car batteries during the day. What kind of solar array would be required to produce 70 amps? What voltage rating would be needed?
It would be very nice to keep the government, foreign interest, the oil companies and the power company out of this equation.
Hey guys. This may not be applicable to this discussion about the electrical service available, but I wanted to make Tesla motors aware of new supercharge ion batteries that are under development by Toshiba and will ready for use by March 2008. I hope this is useful, I really want to see alternative/hybrid/electric cars work and be affordable in the coming years for everyone! ecofuss.com/scib-recharges-in-5-minutes-has-a-lifespan-of-10-years/
Good Luck to all of you at Tesla!
The Electric Motor is obviously an excellent way to go; we just need to keep them clean. But how you get the batteries charged is vertical and volatile.
Of all the options proven to be reliable for charging batteries. I would pick the rubber band theory. Wind it up and let her fly.
Hello,
My name is Sam Birchenough, I am a senior at Skaneateles High School and I am very interested in electric powered vehicles. I am interested in the design and evolution of the electric vehicle. I am doing a 20 page policy paper and was hoping you could help me out with the thought process behind the electric vehicle. I was wondering if you would mind answering a few general questions about your design.
1. Would the technology used in your cars be able to be used in electric cars that would meet the needs of the average middle income American family?
2. What type and what quantity of batteries did you use to power your Tesla Roadster?
3. What is the drag coefficient of your Roadster design?
4. How long did you spend on the design for the Roadster before it entered production?
5. Do you find that having a large rear weight bias (assumed) affects the performance of the car in a negative way (specifically cornering balance)?
6. Does your car incorporate what would be the equivalent of a limited slip differential?
7. Is the steering power assisted, and if so, how is it powered?
8. What percentage of the vehicle cost covers the motor, speed control, and batteries?
9. Is the motor brushless?
10. How does the braking system work and is it comparable in precision and performance to that of a traditional disk braked vehicle?
11. Do you find that cooling for the electronics is something that is tough to address?
12. How does the integrated battery charging system work without decreasing efficiency?
13. How much does the car weigh and what does is the power to weight ratio?
14. Does the car use a direct drive, a traditional transmission, or a variable ratio transmission?
15. At what speed does the car perform most efficiently?
16. What made you decide to produce a sports car design?
17. What do you think is a realistic time prediction for most drivers to be driving all electric vehicles?
18. How many Tesla Roadsters have you sold, to date?
19. Does the car use the speed control or a voltage converter to distribute the power to the rest of the cars functions such as the radio?
20. If you could only have one would you own a Tesla Roadster or an Ariel Atom?
21. What made you chose this career path?
22. Do you own a Tesla Roadster?
23. What do you think the downfall of the EV1 program was?
Thank you for your cooperation and your feedback!
Editor’s Answer: Sam - writing papers is all about research. Most of your questions are answered in these blogs and on the website. Take a moment to do a little reading
I took a look at your website - very nice (apart from the soundtrack!). You didn’t ask, but Nigel Mansell is The Editor’s favorite F1 driver
I just wanted to suggest having the CEO make a few statements on these blogs to get to know him somewhat. Thank you.
# Sam Birchenough wrote on December 19th, 2007 at 2:22 pm
## …lots of questions…
Although editor was right to steer Sam towards further research, here are some comments off the top of my head:
## 1. Would the technology used in your cars be able to be used in electric cars that would meet the needs of the average middle income American family?
That is their plan. To get there someday. Battery costs are still a barrier.
## 2. What type and what quantity of batteries did you use to power your Tesla Roadster?
6831 (18650 size format) laptop Li-Ions. Particular brand/manufacturer is proprietary info.
## 3. What is the drag coefficient of your Roadster design?
approx .3 from what I recall
## 4. How long did you spend on the design for the Roadster before it entered production?
Production is only just now about to start. The company started in 2003 so it has been about 5 years.
## 5. Do you find that having a large rear weight bias (assumed) affects the performance of the car in a negative way (specifically cornering balance)?
Apparently not too much. Rear weight bias gives extra traction on the drive wheels. The car has a low polar moment of inertia and I have heard only compliments about the handling.
## 6. Does your car incorporate what would be the equivalent of a limited slip differential?
Electronic traction control can provide similar benefit.
## 7. Is the steering power assisted, and if so, how is it powered?
Manual steering!
## 8. What percentage of the vehicle cost covers the motor, speed control, and batteries?
Probably proprietary info. Wild guesses: motor: 5%, ESS: 5%, batteries: 20%, chassis: 30%
But they have a LOT of R&D costs to recoup, so that data isn’t too relevant yet.
## 9. Is the motor brushless?
It is an AC inductance motor. It doesn’t need brushes like some DC motors do.
## 10. How does the braking system work and is it comparable in precision and performance to that of a traditional disk braked vehicle?
It is a traditional high performance disk braking system and apparently works quite well. The eMotor does simulated engine braking (by putting power back into the batteries) on the rear wheels to help slow you down as appropriate.
## 11. Do you find that cooling for the electronics is something that is tough to address?
I think the eMotor, and PEM are both air cooled. The battery system (ESS) is water cooled. I think they probably had to do some real engineering work to get all of those cooling systems to function adequately but it was never mentioned (publicly) as a problem area.
## 12. How does the integrated battery charging system work without decreasing efficiency?
I think you would need to explain this question better.
## 13. How much does the car weigh and what does is the power to weight ratio?
approx 2700lbs. 248hp/2700lbs (~0.09hp/lb). The very strong low RPM torque and wide RPM range make it perform 0-60 much better than traditional vehicles with those specs.
## 14. Does the car use a direct drive, a traditional transmission, or a variable ratio transmission?
Two speed traditional transmission. (which is still undergoing durability related refinements)
## 15. At what speed does the car perform most efficiently?
Oof. I don’t remember. I would guess somewhere around 45MPH.
## 16. What made you decide to produce a sports car design?
I think the founders all like sports cars and wanted to have one for themselves.
What they wanted to buy didn’t exist so they had to build it themselves.
Like all entrepreneurs, they decided to turn their hobby/passion into a business.
I don’t think they did this because it is an easy way to make money.
## 17. What do you think is a realistic time prediction for most drivers to be driving all electric vehicles?
Not soon enough.
## 18. How many Tesla Roadsters have you sold, to date?
Last reported they had over 600 deposits down.
## 19. Does the car use the speed control or a voltage converter to distribute the power to the rest of the cars functions such as the radio?
There is no conventional 12v battery for accessories. All of the vehicle power comes from the ESS “traction pack”. I am not sure if they use a voltage converter, or just have a dedicated portion of the pack just for 12v accessory use.
## 20. If you could only have one would you own a Tesla Roadster or an Ariel Atom?
Apples and Oranges.
## 21. What made you chose this career path?
To whom are you directing this survey?
## 22. Do you own a Tesla Roadster?
Nobody does yet!
## 23. What do you think the downfall of the EV1 program was?
Go watch “Who Killed the Electric Car”. They made a whole movie about that question.
If you have more questions start here:
www.teslamotors.com/learn_more/faqs.php
and here:
en.wikipedia.org/wiki/Tesla_Roadster
## Hello,
## My name is Sam Birchenough, I am a senior at Skaneateles High School and I am very
## interested in electric powered vehicles. I am interested in the design and evolution of the
## electric vehicle. I am doing a 20 page policy paper and was hoping you could help me out
## with the thought process behind the electric vehicle. I was wondering if you would mind
## answering a few general questions about your design.
TEG2 answered to some “off the hat” , I do the same to the questions that I would answer a little bit differently.
## meet the needs of the average middle income American family?
Eventually, yes. Tesla is not the only one doing this, lithium-ion BEV is the future of the cars. Until something even better appears. Traditional ICE is obsolete. In fact it has been obsolete for some time now.
## the car in a negative way (specifically cornering balance)?
Roadster does not have large rear weight bias. It is more like middle-engine sports car for weight distribution. It has some bias to rear wheels, but design is pretty much optimal for rear-wheel drive sports car.
It is AC motor. Brushless or non-brushless is value of DC motors.
Power to weight ratio is not directly comparable to gasoline engine power to weight ratio. For that comparision you would get incorrect assumed result for EV performance.
“traditional” two-speed. I wrote traditional in quotes because it isn’t quite traditional in several aspects. First it is electrially actuated clutchless, secondly it has to go from 13000RPM to approx 6000RPM in fraction of the second. That isn’t quite traditional other than it is fixed ratio.
From 0 - to approx 6000 RPM. That translates to about 0-30mph first gear, and 0-60mph at second gear. See www.teslamotors.com/performance/acceleration_and_torque.php
Thing is that efficiency of eMotor is about 90% to huge RPM range starting from zero RPM, very much unlike gasoline engine which has only few hundred RPM “window” of decent (much worse) efficiency. That makes it very difficult to directly say which is practical efficient speed. It has pretty much optimal efficiency at any speed.
“All electric” is very difficult to predict, because for long road trips you need recharging possibilities in roadside and that infrastructure simply doesn’t exist (yet). “Serial hybrid with more than 90% driving made with battery only” might be as soon as 10-15 years for now, and not much later. That’s because EV is simply superior in both performance and maintaining costs compared to old ICE tech. Only thing limiting that to happen _right now_ is current high price of batteries, but if my info is correct that will be changed in few years pretty dramatically. See what Velozzi is doing (www.velozzi.org). Also battery price will go down to 1/3 or lower in couple of years.
Roadster. I’d like to have some luxury like air condition and a roof in case it happens to be rainy day. Ariel Atom is more like a race car.
TEG2 asks “To whom are you directing this survey?” and I second that question. This is a blog and this particular blog is “Views and perspectives from Martin Eberhard”. Martin is not a part of Tesla group anymore, so you are directing this to readers by writing these questions here.
TEG2 said: “Nobody does yet!”, but that isn’t quite true. Roadster no1 has been already delivered (Elon Musk car).
Big oil companies got scared about success of EV. Watch “Who Killed the Electric Car”.
A very impressive product. I eagerly await a production version (i.e., affordable for the middle class) of the technology. With a little luck, the USof A could become an exporter of oil? Please hurry!
# Timo Wrote
## Roadster no1 has been already delivered (Elon Musk car).
Has it been delivered? I think I read it “already came off the production line”, but I don’t know if it has been delivered already.
I hate to seem rude, but this is really kindergarten type stuff regarding electrical requirements.
Three points:
1). The range demand factors (eg: use 8kw for a 12kw range) is I HOPE obvious. Its almost impossible to have all 4 burners on high, and the bake, and the broil elements on for any length of time unless you’re purposefully trying to trip the breaker. This does not apply to the TESLA, since (again, they don’t say, but we’re left to assume) the charging rate will be constant throughout the duration of the charge.
2). Utilities in general charge a demand charge (aka electric ‘fine’) for any customer using usually more than 10 kw at any give time, and could cancel (cheaper) residential rate allowability. Why? In residential areas utilities usually have a 25 kva (lets call it 25,000 watts to avoid the powerfactor discussion) transformer for 12 homes. If too many customers have too many huge loads, the transformer will blow its top, or, at the very least, shorten its life. So, If you’re charging at home, forget about a fast charge until there is a cheaper way to buffer electricity.
3). During the 1/30/08 town meeting, the discussion by TESLA personnel was about homes having 40 amps available for a ‘dryer’. The only 40 amp availabilty in homes in the USA is by STOVE,RANGE, OR WELDER outlets (and then only, by those that have 50 ampere circuits for the outlets, and not the many that are 40 or 35). Dryer outlets are limited to basically 24 amps (actually, 22 amps of 240 and 4 amps of 120 - but the previous statement isn’t too much of a simplification). The official statement by TESLAMOTORS was just plain wrong. Very embarrassing that they don’t know this. I’m still hoping for an official spec-sheet on the Tesla. But listening to this ‘town meeting’ was unbelievably discouraging. It sounded as if they don’t know enough about their own car to even come up with a firm spec-sheet. And, I could never plop down a $50k deposit on something that is still in the vapor-car area. Weren’t there 48 TUCKERS actually built also?
Martin:
The ‘non-coincident loads’ are, for example, room air conditioners and baseboard resistance heaters. I hope this is obvious, but you either heat, or cool your house in general. In a very large house, you might use resistance heat as ‘REHEAT’, for humidity control, but then the REHEAT IS Coincident. Tesla’s are in no way, shape nor form ‘non-coincident’, since you could recharge at any time of the day. In any one house, there would be no ‘demand factor’ applied to the TESLA, since you are either charging, or you are not. Such loads would be considered totally additional to whatever service entrance calculation was otherwise arrived at, either through the standard, or optional calculations. Hopefully, this is just common sense. I suspect if there is ever more than trivial usage of electric vehicles, utilities will insist on demand limiters (devices which allow either the DRYER to work , OR the TESLA to recharge, but not both at the same time), for the reason I gave in the previous post. I find the NEC (NFPA 70) reasoning perfectly natural. Email me if this has not become Crystal Clear to you yet. - Bill Howland
I guess I dont really see the point of the spreadsheet. How many ranges will tesla’s customers have? Two at the most I would think. Another thing I have not seen addressed anywhere is how about those customer’s whose maximum voltage available is 208 (brooklyn, queens, (& other densely populated cities), appartment dwellers, etc). If that is just something Tesla wants to ignore, the customers could get a buck/boost transformer to jack it back up to 240. But we still don’t have any hard info from tesla on how to adjust the charging rate, and what happens when the voltage to the car changes.
To Russ Sciville: 99.9% of homes (and yeah, that’s an accurate number) in the U.S. are not ‘110 volts’. Half the 110 volt loads are in a series circuit with the other half of the 110 volt loads. Its old, but not an ‘antiquated’ system. Shock hazzard is much, much less than in Europe with “mains to earth” voltage of 240 (here it is 120). Distribution losses from the serving utility are calculated at 240 volts, since that’s essentially the load presented to it by the typical house.
Martin: I’ll end on a bright note: It’s my guess, that if customers of yours judiciously chose their recharge time, they could run a 70 amp (230) charger on their 100 amp service in the middle of the night. But the minimum service for purchasers of a $100k car are going to have a house w/ 150 amp minimum service 98% of the time. So if they have 2 spare spaces for the breaker in their existing panel, its a go. As I mentioned a few posts up, only one Tesla allowed per neighborhood or else the power company’s transformer will blow. So, for the time-being, I doubt that any initial customers of your cars will need to change their electric service, though we electricians charge a bundle for running 70 amp dedicated circuits to detached garages. - Bill.
P.S. Final questions i have not seen answered anywhere.
1). You say inv eff = 90%. What is the charger efficiency, considering power in/out of the charger alone.
2). What is the battery (ESS) charge efficiency, considering the battery (LI-ION) (including steering diodes) alone?
3). What is the battery discharge efficiency (ESS) including all losses with the exception of the 90% eff inverter?
4). Are the charging rates variable, or are there 3 fixed rates, (I assume 1 - 115, and 2- 230 volt). I see ‘charging module’ , “charging station”, and ‘extension cord’ used interchangeably. I suspect that the ‘rectifier function’ is built into the inverter, and there is no charging station, merely cords with differing plugs, but again, We Need A Spec Sheet. Thanks.
EEStor, which sounded pretty much like vapourware, has signed a supply agreement with Lockheed Martin.
thefraserdomain.typepad.com/energy/2008/01/eestor-lockheed.html That’s a HUGE vote of confidence.
If these or nanowire LiIon batteries with “10X” the energy density and “60X” the charge rate actually become available, I’d expect people would go to commercial/industrial charging outlets for a 500-Amp boost. Their range would then be 1-2,000 miles, and that would make up for the inconvenience. Home top-ups could be done just as a matter of non-urgent convenience, with only very rare visits to charge stations.
I performed the study using your spreadsheet and I got :
177 A
23 A available
The house is 2300sqft with 200A service. Located in CG Arizona we are equipped with two heat pumps that need 55A. If I should get an electric vehicle I would probably need another service line or if possible a device that cuts off the charger just before the heat pumps kick on then goes back on when they cut off. Is that even possible at a reasonable cost? The whole electric car idea is exciting and I hope it goes big.
Regards, Tom
Why not put the current shunt at the entrance lead to the house, and have the charger automatically vary its draw according to the preset max ampere value and time of day. This way if i set 100A max for total house electrical load, and my house is pulling 20A the charger will pull 80A. If the air conditioner kicks in, and asks for 30A, the charger will lower its draw automatically to 50A to keep total load under 100A. My Xantrex inverter/charger already does this to protect 15A circuit breaker when charging the battery and supplying the load from the grid.
I just filled out your Excel spreadsheet and found that the Total Required for my home (as currently configured) comes to 197A and leaves me with 3A remaining. It looks like I’d have to upgrade to a much larger capacity service for my home, if I add any high consumption equipment.
This is not a surprise. This home was built in 1965 as an all-electric home. Of course, these figures don’t tell the whole story, since our power consumption (as calculated from our electric bill) doesn’t come close to the maximum available power from our service.
Our maximum power useage is in the winter in Eastern PA and in the summer, our usage drops to about 1/3 of that.
Our local power company (PPL [www.pplelectric.com]) recently installed remote-reading meters throughout their coverage area and promises to have “hour-by-hour” power consumption listings available to each of their customers on their web site by the end of 2008. I’ll be very interested to see what that looks like when it’s available.
Tesla is quite a fascinating car. Yet most of the discussion are concentrated in the performance of the electric battery, what about the safety of occupants? As you mentioned the Roadster is equipped with two frontal air bags (driver and passenger), then what about the protection from side impact and rollover? I realize that to make the body light is a trend and must for EV, but safety is still an inevitable problem especially for a convertible like Roadster, do you have any solution to it?
With the winter months coming in thick and fast I have noticed the difference in how much my energy costs are compared to last year so I think it is definitely a good idea to search for a cheaper electricity supplier.
