Meld dig ind i fællesskabet
Meld dig indLog ind
Useable Battery Capacity 85Kw
Has anyone been able to determine what is the actual useable battery capacity for the 85kw battery at both standard and range charge. I know it is less than 85KW but how much is available?
I drive a Signature S #175 85KW. I drive from Jacksonville to Tampa 202 miles and have about 20 to 40 miles of range remaining. That is with some cargo that weighs about 200 lbs driving mostly highway at speeds of about 70 to75 mph. Due to the Florida heat I use AC is on the whole trip. That's on a full charge or 268 miles of rated charge or the max charge. Hope that helps.
Rbeninati1
Have you noticed what has been the most KW/hours you have up?
With normal LA driving (70ish on freeway, some traffic) I've averaged 350 wh/mi or so. Since "rated" is 300 wh/mi, and "distance charge" is 275 miles or so, that would amount to 82.5 kWh. In the end, what matters is efficiency and range. I created a spreadsheet that has reference charts and has calculations for stuff like this at http://hannelconsulting.com/tesla/TeslaOperations.xlsx
cliff@hannelcon
Thanks for your worksheet. Nicely done and interesting. I saw you estimated 82.5 kWh of battery available. I thought I saw somewhere in the forum that the standard charge only charges the battery to 70.6 kWh and the range charge to 81.3 kWh. Wondering if anyone can confirm these numbers.
It appears to me that 95% (80.8 kWH) is available. You can access the rest by driving beyond zero miles remaining, but the car progressively restricts the power and eventually forces you to the side of the road in order to protect the battery.
Jack
You cannot drive past 0 miles. The car will just stop.
schoen;
wrong. Various people have done so, with the results Jack describes.
