Homelink....Please help
At my home, I have a wireless keypad on the outside of my garage door. When I set my Homelink on my Model S, my outside keypad stops working....When I set my keypad than my Model S stops working. Any ideas?
It would have to be something in your garage door opener that only one works at a time -- do the docs say anything about it? Did previous cars cause the same issue?
This is probably of no help to you but we have the exact same setup - outside wireless door opener on a keypad. We programmed our Tesla homelink and everything is working fine, incl. the outside keypad.
Thanks Carefree...at least I know it can work
Jar....Other cars no issue. Have do look at docs.
Any other advice appreciated.
I would try completely clearing out the memory of the opener... look at the opener manual for steps. Then reprogram both the Model S and keypad. It may have some old codes still programmed and it's running out of spots.
If all else fails... call Homelink and have them walk you through the reprogramming.
jfeldman. I too have the same arrangements as you and my DS was able to set it up.
I don't think it's a Homelink issue, but a garage door opener memory issue. Resetting the opener memory (and reprogramming every remote opener, including Homelink) has worked for me in the past when I had issues with too many remote openers registered with the opener unit.
Guys, Does Homelink come with the MS without the tech package?
I believe this is a garage door opener problem. My GDO will accept four transmitters, when I try to add a fifth, the first one drops off. call the GDO help line, and explain the problem. mayaring entire memory and starting over will fix it.
"mayaring"??
maybe erasing?
@akikiki: no, Homelink only comes with the tech package.
It could also be that in programming them, you're holding the learn button the garage door motor for too long, which usually causes it to erase everything. That could certainly explain the behavior you're seeing.
@salman; thanks for the reply. Much appreciated.
There's Homelink add-ons available. Just will not be on the screen.
I have a wireless outside keypad also and that continued to work fine after I programmed homelink in my Model S. It's always worked fine with every homelink programming in every car we've had.
What did stop working for me after programming the homelink in the Model S was the handheld garage door opener. That needed to be reprogrammed from scratch and then everything was dandy.
I would guess your holding the sync button on the door opener too long. I programmed mine yesterday and the handheld stopped working until I reprogrammed it to the opener. Now both work fine.
@salman
Please advise where I can find Homelink without ordering the Tech package.
Thanks
@ra.cooper
I think you may have been directing your question to me.
I've seen "homelink remotes" on Amazon. Simple search will bring them up. Some appear to be visor clip-ons. Might not be much of an improvement over the regular remote - just don't know.
I just replaced my GDO, to be able to use an iPhone app and web to check the garage. Sears has a GDO that connects to the Internet, and it's Homelink compatible.
