persistent fan noise behind the 17" display
I just got my car this morning. Ever since early afternoon and throughout the evening I am hearing a non-stop fan(like) noise behind the 17" - more to the upper side than lower. I went out to dinner and got back and it was still running. Almost sounds like a cpu fan that doesn't shut off. Maybe it's a battery fan? But that seems a bit high in the car and I am not sure why it would keep running for as long as it's been..
anyone else had something similar happen?
was it hot outside when it was parked? I hear it when the temps reach 75 or higher.
Was told by a DS that it is a cpu fan behind the display. It goes away once the temp drops below 70.
I had this. Wouldn't go away. Finally, I took it in and they could not make it go away except by pulling the appropriate fuse. Hasn't come back since.
hm ok I guess I will see if it's still running tomorrow and if so, I will stop by the menlo park place.
OK so I stopped by at the service center in Menlo Park. They were of course super nice and helpful. Seems like this is a known problem, they said "ok we know what's up" before I finished my sentence. There's a glitch in 4.4 (sounds like it will be addressed in 4.5). The fan starts when it gets warm, but doesn't get turned off when it cools down.
He pulled a fuse for a few minutes to reset the thing, then plugged it back in and the fan had stopped and the noise was gone.
Love the car! Day 2 :)
Do you know which fuse? Will you have to pull it every time you get home?
I guess every time it gets hot. Right now it's ok. he pointed out that there was a heat wave last week however I got the car yesterday so that wasn't it. Now I do have the front license plate panel thing. I wonder if that makes it worse.. hmmm
anyway it was the yellow fuse towards the window on the right.
per the owners guide it would be fuse box #2 (page 26) F51 which makes sense as it says "Touch screen".
I have this problem as do a number of other people in the Telsa FB group. Thanks for the information.
Thanks for the thread, I have the same problem.
Tesla just took my car in to the shop today for the same (I think) issue. I'll report back what they tell me...
I called service and they also said that would be fixed in the next release, maybe two weeks. He said if it starts making grinding noises, to call right away. As for the fuse, I believe it is number 51 according to the user guide.
Thanks for your posts guys, I have the same problem. I got the new version 4.4 and we are in a heat wave in the Ottawa area.
I will try removing the fuse. This forum is great!
FWIW, the day my delivery was scheduled I got a call from the delivery center. They were putting mine on the truck and heard an unusual fan noise from behind the display. They needed to get a module shipped to fix it so we agreed to postpone 1 week. My garage wasn't quite ready anyway, so it was really for the best. The pressure was off me and THEY found the noise, not me, which was far better, but felt longer than the 3 years I had my reservation! Got the car on the new date and it has been perfect. I never heard the noise so I realize this probably doesn't help, but I couldn't see any harm in sharing the story. Best of luck.
The other day,
....Upon the stair
I met a man
....Who wasn't there.
He wasn't there
....Again today
I wish, I wish
....He'd go away.
62 degrees on a gray, June, L.A. morning. The car has been sitting overnight. The fan motor is whirring away loudly. This is not a heat related issue.
My fan noise began about a week ago. I stopped in the L.A. service center to ask about it and was told it was normal. It's not, it's new. It's a small annoyance to give up the time to wait for them to deal with it at service, especially if they don't see it as an issue. From what I've read here, it's a known issue. Not sure how to proceed.
Remove all the grease from the axel and spin the wheel rapidly.
@bob@follow
" I stopped in the L.A. service center to ask about it and was told it was normal"
Ok, if it's normal, I have to get my quiet one fixed. There's no noise.
Pulled fuse #51 myself today, fan noise still remains.
When testing the new 4.5 feature of low amperage charging while the AC is on (and plugged in) I noticed the fan noise when entering the vehicle and the AC was OFF. This is new and did not happen in the previous 8800 miles. This does destroy the previous perfect quiet quality that Model S was famous for. It's like turning Dolby noise reduction off when the music is on. The low background sound is annoying.
Maybe CU will drop the rating to 98.
@hsadler
Normal was what I had before, no noise. Now, like others, I have noise. Is noise the new normal?
The fan noise is distinct from the hard drive that can also be heard spinning behind the nav screen correct?
@bob
"Is noise the new normal?"
According to Tesla service, NO. They are working to re-release 4.5 firmware with the fix.
I pulled the #51 fuse and waited about a minute before putting it back. The persistent noise behind the screen that has been bothering me for a few days disappeared instantly. I parked in the sun the whole day today with interior temps reaching the high 90s but the noise has not returned.
@Robert22 - "The fan noise is distinct from the hard drive...."
There is no spinning hard drive. They use flash memory for storage (i.e. it's silent).
@redshift
No fan noise from Dec thru April. May it began for no apparent reason. 4.5 downloaded 2 weeks ago without any change. Haven't tried pulling the #51 fuse yet.
Oops, missed "re-release" 4.5.
So for those with with no noise and those who did the fuse pull, when sitting in the car with everything off, is your MS completely silent? I am getting this slight electrical hum coming from behind the touchscreen and don't know if that is the same as your fan noise. I pulled the fuse and the sound is still there.
Tee,
That's the fan noise. For me too, it didn't go away after fuse pull (tried to times).
We just have to wait for next firmware release according to service rep I talked to.
Running 4.5(1.33.48). I had not noticed the fan noise until I finally turned off the climate control and everything else. I also pulled fuse 51 (the 20A yellow one nearest the windshield, fuse box 2), waited about 40 seconds, the fan noise is still there. Do you have to wait the full 60 seconds? I also tried rebooting both screens, power-off, leave car, lock it; nothing made it go away.
The noise really doesn't bother me, but the extra battery drain does.
Got this one today, after one day of ownership, loud fan behind the display. In fact, it's loud enough to hear it outside the car.
I also tried the fuse pull, 60 seconds, with no improvement.
I have Software 4.5 v1.33.48
i also have the fan noise after upgrade to 4.5. Since I read this thread it was very obvious and now is annoying. I pulled fuse 51 and sat in the car, no noise. replaced the fuse and it seemed better for a short time, but was right back in no time. anyother recommendations?
