USB can it be set to provide continuous 12v output
Any thoughts on why the USB or aux 12v are not active when the Tesla is off? Would like the option of leaving my iPhone in the car to charge when parked.
I believe the USB connection is on continuously, but the 12v plug is not. Thinking about it, there might be a way to rewire the fuse box to allow continuous 12v power on the 12v plug, but I haven't heard of anyone doing this.
Yes, for me, I use the 12v plug to recharge my ipad via an adapter, and it would be nice to have it always powered.
All USB ports provide 5 volts DC, not 12v.......
Mr. Brown, thank you for providing more procession regarding USB vs. aux. port voltage.
Shop:
Could you test for me your hypothesis that your Model S USB's continue to be live when the car is "off".
Thanks
The USB does provide continuous power. I have left my iPad with about 40% battery left in my car overnight, and it recharged it completely. I have done it more often than I should.
+1 amneet - I left my iPhone plugged into the USB port in the car and it was kept fully charged even though the vehicle was locked and dark. I love that!
@barton.stl - Yes, they stay on.
It will probably be turned off with new 5.6 update to conserve battery power (unless you turn that feature off i.e.if you turn power conservation off). Just guessing, by the way.
Mine does not stay on. I've tried to leave my phone plugged in and it turns off a few seconds after the screen turns off. I have an android phone, I can easily verify this as there is a charge light on the phone.
I'm on the latest 4.5 software.
Thanks all for the comments Will consult service and see if I can find out why some stay on and others not. Will post my findings
Thanks again
Get one of those USB powered lamps to verify visually from well outside the car. ;-)
The drain from charging an iPhone would be far less than a mile. That's about 300Wh! The iPhone holds almost 6. >;p
