I'm getting my MS in a few weeks! does anyone have any experience charging primarily with a 110v outlet? I don't drive more than 20mi/day on avg, and I rent my house and am debating whether or not to install a 240v outlet or not, as i may move in the near future. Any advice much appreciated!
If you drive <20mi/day you should be ok. During the work week I charge only at work during an 8hr shift from a 110 outlet. I only live 6 miles from work. I usually get ~30 miles of charge in 8 hours.
http://www.teslamotors.com/goelectric#charging
According to Tesla looks like about 3.5 hours. Although that calculator shows 120v not 110v.
I've had my S for a week, and used a 110v for a few days until my NEMA 14-50 was installed. 110v doesn't cut it. Trust me, you will be driving your S a /lot/ more than just to and from work. Get the 240v NEMA 14-50.
Load up once a week at a high-power chargespot, and "hot the fort" at home with the 110.
Duh. "hold the fort"
Obvious solution is to start with the 110v, see how it works for you for a few weeks and if its not good enough get the 240v outlet installed.
Are there any LevelII charging options in your area? You could lean on public chargers to bridge the gaps if more miles are needed etc.
You should be fine. I have been living with 110V for a couple of weeks. More info on my blog:
http://teslaowner.wordpress.com/2013/02/11/living-with-110v/
You should also consider climate. If its really cold where you live, less power will be available to the battery. But I would try the 110 first. You can change later, and Blink and Chargepoint get you 20 mi per hour for a buck.
And you probably will drive more... its so fun!
Agree with others that you will want to drive more after you get your S. I lived with 110V for a week, you can expect about 25 miles back overnight at about 2-3 mph. Even if you don't need more than that, you will be cutting it close and it will be in the back of your mind. So much happier with my NEMA 14-50, it was liberating.
Reidcarolin. IMO, I recommend installing a Nema 14-50. The 110V will just cover your daily trips with overnight charging . The day you decide to take a longer you will understand the need for 240V charging. I took a 90 mile trip and plugged in at a 110V and it took 20 hours to add 40-50 miles of range! MY home charging takes 3-4 hours to recharge 90 miles of range. The best $500 I ever spent.
You won’t always drive just 20-30 miles in a day.
@reidcarolin's problem is he rents the house.
110V is soooo slow!
Do you have a dryer plug?
That is still a challenge. You need an adapter for the dryer outlet, not easy. You also probably need an extension cord. Yes, it is safe, if you buy one that can handle the current. Lots of forum discussions on outlets, dryer plugs, extension cords.
We used a 110 plug at a friends house and got 3 miles/per hour of charge. we didn't drive our car much while there so it was fine..
If the landlord will let you, even if you spend money for a 14-50 outlet that you won't take with you, it shouldn't be that significant an expense compared to the car.
You should be able to get the 240V outlet installed from $250-500. Well worth it in my opinion, especially considering the price of the car.
I too, could survive day-to-day with just 110V outlet charging. However, there could be those days when you do end up driving 100 miles. What about when friends or family are in town and you're showing people around, giving them rides etc? What about the weekend you're doing a home project and you end up making several trips to the store? Or you're going shopping for something big and "permanent", like furniture, and so you want to drive around and actually look at things in a bunch of different stores?
110V isn't going to cut it in those situations.
Hey just wanted to make a clear forum one where some rumored superchargers are being set up!
Please add source!
DO NOT ADD WHERE YOU WOULD LIKE...
