Have been waiting anxiously for months for my car to arrive only to find out that the twin charger I ordered is on back order. That's fine but Teslas solution is for me to get a nema 650 installed in the meantime. I'm o.k. With that but they only offer a $200 credit. Not nearly enough to cover the expense of that. Very unfair.
As was mentioned elsewhere, the connections to the 6-50 and HWPC are in common, the same. Only a swap of wall units will be necessary.
$200 sounds more than fair to me.
BTW It's likely that it's the High Power Wall Charger that's backordered, not the Twin Charger which gets installed in the car itself.
@joehuber| FEBRUARY 20, 2013: BTW It's likely that it's the High Power Wall Charger that's backordered
Yes, agreed. And it's called a High Power Wall Connector. It does not do any kind of charging - that's done by the onboard chargers. See http://www.teslamotors.com/charging#/highpower
We hear a lot about the efficiency, lower emissions, silent operation and other advantages of EVs. A somewhat overlooked aspect, IMO, is the effect on both...
