Blake
Without sleep mode (which was added in 4.0 but removed in 4.3), the computers in the car use up about 8mi/day regardless. Also, if it is cold, the car will use some energy to keep the battery warm enough to avoid damage. This energy used doesn't come back (though if you keep the car plugged in, it will periodically charge to replace the power used).
Aside from that, there is the issue you discussed, which is that the computer calculates the range based on how much energy it can extract from the battery at the current temperature, not taking into account that the battery will warm up with use. That is the only "charge" that comes back, and it simply reflects the calculation reflecting the warming battery temperature.
One other thing is that if you make short trips, you will use much more energy than typical, because you will be running the heater full blast for the entire trip to warm the cabin, and then by the time you get back in the car it will be cold again. As an example, I typically average around 370Wh/mi the way I drive, but when I was out of town and making lots of short trips in below-freezing weather, I was regularly using over 900Wh/mi on those short trips.
You really should keep the car plugged in when you are at home.
I have never seen my rated miles actually go up. On the other hand, I have never seen it decrease by 30% when out in the cold and not charging. Usally it is about 1 mile per hour, maybe 1.5. I have seen the projected miles higher than the rated miles. Also, there appears to be a characteristic cold spike in the energy graph that occurs when you drive the car cold. This goes away after a period determined by how cold it is, how cold the car is, and how fast you are driving. jat is right that the worst driving is short trips followed by long periods in the cold. I drive about 35 miles to work and I find that the Wh/m starts over 400, but by the end of the trip is in the 320-340 range. I second that you should really keep the car plugged in and I have tried a few times to warm the car before unplugging. the best result I got was when the charging kicked in and warmed up the battery prior to leaving. You can actually force this by shifting to range mode and then back after it starts charging. I don't think that that hurts the battery.
I received my car about a month ago and its been pretty cold here in the northeast. I would say most nights in the 20s or low 30s and several in the teens. I see about a 1 M loss per hour in the cold and another tax of about 10 M to warm the battery when initial driving. You also lose all or some of the regen capability when warming the battery. What I have done to combat this is I set the charging amperage such that it completes charging about when I am leaving in the morning, i get the full range available (not that I really need it) and more importantly I dont have to warm the battery and have regen from the start. this has worked very well for me as a stop gap until they deliver a software update to allow scheduling of the charging.
@blakehajek
What you are experiencing is about the same as the guys that just did a trip to Groton CT to replicate NYT's debated test drive. After super charging (MaxRange charge) at Mildford CT and arrived at Groton (55 miles). They left the cars outside of a hotel at 22 degree F overnight WITHOUT plugging.
https://twitter.com/TeslaRoadTrip
Car 1:On arrival 196 mi rated remaining -> after over night 169 mi
Car 2:On arrival 198 mi rated remaining -> after over night 171 mi
Loss of 27 mi each car, which is about the same as yours. Then they drove highway around 65 to 70 mph with heater at 70 to 72 degrees, which used more energy compare to traveling ideal 55 mph with no heat on. So from Groton CT to Tesla super charger station:
Car 1 drove 81 mi with 73 mi remaining = 154 mi
Car 2 drove 67 mi with 74 mi remaining = 141 mi
So the rated miles in the morning before they left is pretty close to the final tally, depending on speed, heater use.
Another example, Consumer reports reported 140 mi rated remaining, after overnight, 65 mi (probably even colder temp over night) rated remaining, then he drove locally for 30 miles, and the car states 55 mi remaining, which means the car can go total of 85 miles, that is 20 mi more than the rated 65 mi in the morning.
http://news.consumerreports.org/cars/2013/02/tesla-model-s-winter-chills...
Anyhow, the car will use power to keep the computer running and keeping optimal condition for the battery. I rather the car use the power to extend the battery life than not. The low outside temp also plays a role, and after you start driving, the battery heats up plus the heat from the electric motor is diverted to heating the battery, the range will improve a little, which in consumer reports' case, it replenished about 20 mi.
Bottom line, plug in the car whenever you can, especially in the winter. Topping off the battery everyday will also extend it's life.
I have a 40mi round trip commute into NYC. In subzero degrees Celsius temperatures, my drive to work consume between 400 and 500 Watts/mi. In the evening albeit when the temps have climb above the freezing mark, my car consumes electrons at the same rate but completes the 20mi home leg with no loss in range. All battery chemistries shrink in the cold including Pb acid batteries.
Small correction to @Jat's post to avoid any confusion: sleep was removed in 4.2; 4.3 isn't out yet.
@nickjhowe - what I intended to say was removed in 4.2, and should be back in 4.3, thanks for correcting.
Guessed it was! Didn't want the noobs to jump in with all the "I don't have 4.3 yet...." comments. :-)
And no offense meant to the noobs. You're most welcome here.
The NY time reporter had the same problem too when he test the car.
Here is some more data from a few days where my Model S was parked (temp ranged from 40-70F). As you can see, loss averages around 0.5 mph (12 miles per day), but estimated range does go up when temperature warms.
Date/Time EPA Range Avg Loss Rate (mph) Incr Loss Rate (mph)
2/15/2013 15:45 121
2/15/2013 21:59 118 0.48 0.48
2/16/2013 12:41 100 1.00 1.22
2/16/2013 16:26 106 0.61 -1.60 (WARMING)
2/17/2013 21:28 97 0.45 0.31
2/18/2013 6:45 81 0.63 1.72 (OVERNIGHT COOLING)
2/18/2013 8:42 77 0.68 2.05
2/18/2013 14:47 87 0.48 -1.64 (WARMING)
I'm an engineer and am able to estimate range/conditions/etc (and enjoy it!), but to be really mainstream, I think Tesla can/should do more to help drivers manage their driving - they have not been really clear/open about parking- and temperature-related losses and the on-board tools and the app don't really help you estimate where you really stand. For example, they could integrate Nav, Weather and Energy apps and really give you a trip planner that takes a lot more into account. Right now, for example, I have to consider speed, route (climbs) and real-world consumption to plan a trip. For example, while you might have enough total energy to get home based on average consumption, if there is a big climb shortly before you get there you can still run out before the top! As more non-tech and non-early-adopter types buy, it will be too easy for them to mis-estimate and get stuck with the current tools.
You can download the reference sheets I use from http://hannelconsulting.com/tesla
(formatting on table above got screwed up...it is also in the spreadsheet)
As we get more data from the streaming API, you can see exactly how the charge goes down over time, and coupled with ambient temperature readings we could more accurately predict actual loss rates.
cliff;
Here it is using the "pre" tag, just about the only way to tabulate in this forum (H2 added for clarity; 'pre' shrinks the font somewhat):
Date/Time EPA Range Avg Loss Incr Loss Rate (mph) Rate (mph) 2/15/2013 15:45 121 2/15/2013 21:59 118 0.48 0.48 2/16/2013 12:41 100 1.00 1.22 2/16/2013 16:26 106 0.61 -1.60 (WARMING) 2/17/2013 21:28 97 0.45 0.31 2/18/2013 6:45 81 0.63 1.72 (OVERNIGHT COOLING) 2/18/2013 8:42 77 0.68 2.05 2/18/2013 14:47 87 0.48 -1.64 (WARMING)
jat;
Somebody typo'd the "Steaming App". Sounds more dynamic!! ;) But rude ...
Ran my own little test when I got my car. Garage temps were between 54-59 degrees. Charged up to rated at 241 and unplugged it.
Checked SoC at 6pm daily to monitor losses.
Started at 241,
228,
214,
202.
Monitored battery temps as best I could by measuring bottom of car.
At the point I unplugged, it was at 71 deg. After that it dropped to around 64 degree +- 1 and maintained that temp regardless of garage temp changes.
So 12-14 mi/day of loss seems like the vampire load regardless of temp when sleep is not available. Any 60kwh owners measure whether the loss is comparable, and if so is it a comparable % loss or a comparable loss of miles?
@riceuguy - it should be more like 8 rated miles/day, not 12-14.
I lose about 8-10 miles for 12 hours not charging (overnight).
My car is sat at Miami airport - and will be until Saturday morning. Here's the story so far:
Uploaded from Photo Slice
By advanced mathemagics, I deducts that it deducts 10 mi. day. Like Macbeth, it wishes it could sleep.
@BrianH - but would it dream of electric vehicles jumping over a fence?
@jat: very funny!
@nickjhowe: thank you for the straight-forward presentation. All the charts and graphs were quite confusing. Your idea was clear and concise.
I have a 60kWh battery. I unplugged this morning around 178 rated miles and drove 6 miles to work on a 19F degree morning. I think I had 171 miles when I got here. My app now shows 161 miles but that's over 3 hours of sitting.
I dunno, I'll ask Phil when I see him.
@Sudre_ - note that is conflating actual charge loss from heating the battery and running the electronics, with a reduced estimate because of the temperature of the battery -- the estimate only considers the battery's current temperature, and not that it will warm up with use.
It should be possible to adjust the min temp for the battery heater. My Leaf's battery only starts battery heating below -22C..
Or, even better: When unplugged do not start battery heater unless temp goes below -22C. And if battery heater starts in this case send me a warning via SMS.
dahtye;
the general rule for capitalizing unit abbreviations is whether they are names of people. So kilo Watt hours is kWh. mega Hertz is mH. Kelvin and Celcius and Farenheit are K, C, F. And so on. Numbers and time periods are lower case.
@Brian H - I hate to get off topic but but megahertz is MHz and millihertz is mHz. H is for Henry (unit of inductance) not Hertz (unit of frequency). mH would be millihenry.
Metric prefixes are lower case for 1 000 (kilo) and smaller, and upper case for 1 000 000 (mega) and larger. See http://en.wikipedia.org/wiki/Metric_prefix
Hans;
right you are. Not an SI native, so ...
