are there any special requirements to adding a subwoofer?
There is no car to mount it in, yet so there can be no answer to this question.
I was thinking about either hearing aid or hearing protector depending how much noise object had already suffered.
Direct mount to the top of the skull gets the best results.
Ha ha! Great answers! =) I for one wouldn't be opposed to changing out the speakers though if they are anything like the "paper" ones that come in most cars. I think the only major stumbling block you'll hit with installing a subwoofer in a Roadster will be space requirements. The Roadster is a tiny car just like most (if not all) other super cars.
can someone at least post the trunk dimensions for the roadster 2.5 please?
i heard on the internet that there was a custom one that required a separate battery.
i like alpine, but i want to put some shallow 10inches in the back, probably some hi end tweeters and mids in the front, an amp, a capacitator if necessary.
10 inches deep (without the soft top depression) x 14 inches x 55 inches. The depth with the soft top depression is 14 inches.
Does anyone know the best place to run a cable/wire from under the hood into the cabin (this is for a radar detector)?
I have a JL audio 8" sub in my passenger's footwell. The amp for it is also from JL audio, a very efficient 300 W amp - it runs off the main battery not the aux battery so there's no additional battery that it uses. The only issue is that now there is less foot room for a passenger ;(
Can I? We installed the NEMA 14-50 outlet for our Model S. We then just bought a used 2008 Roadster. Is there a way to adapt the Roadster to charge from the...
