Imagine the following:
Electric motor power = 75 kW
Operates at max voltage of 420 Volts
Battery Pack size is 48 kWh
Cell specification: size 18650, 4.2 Max Voltage, 3.6 V(Nominal) and 3 Ah capacity.
Some basic math:
For 420 V (to operate the motor)i connect 100 cells in series with each having 4.2 Volts
Now 48 kWh = 48,000 Wh / 420 V = 115 Ah
Also 115 Ah / 3 Ah = 38 Cell in parallel
So total cells are 100 x 38 = 3800 cells making 48kWh battery pack.
Now-------------!
When pack is fully charged the voltage = 420 and capacity = 115 Ah
For 75kW requirement ----- 75,000 W / 420 V = 179 amps required
Thus my max C-rate when battery pack is fully charged is = 179 amps / 115 Ah = 1.55 C rate
Now imagine the cell voltage has reduced to around 3 volts and capacity to around 0.4 Ah
Thus battery pack voltage is 300 volts and capacity is only 15 Ah
Now at this time if i need 75 kW of power from the pack than,
75,000 W / 300 V = 250 amps required
250 amps / 15 Ah = 16.7 C-rate !!!!!!!!!!!!!!!!!!!
Is this logic true ???????????????
_________________________________________________________
great question.
The confusion is between mA and mAh. The mA ability is combined with the voltage to define the c or current.
The mA actually stays fairly constant. You are thinking of the mAh which has declined with use.
This is what i think.....
mA or just Amps vary constantly......
because speed varies so power requirement vary....
Means kW vary now p = V * I
V has range of 4.2 V to lets say 3 volts
at battery pack 420 volts to 300 volts (for 100 cells i series)
in that case I will vary my friend
and current is time dependent so amps is amp-hr
which gradually decreases from 3Ah to 0.4Ah (or 115Ah to 15Ah)
we can limit the C-rate provided on has to bare the performance reduction as battery pack is discharged.....
To all Tesla-roadster users---------------
is your car giving the same performance like max velocity of 125 miles/hr and 0 to 60 in 4 sec--------
when your battery pack is almost discharged?
like if 56Kwh is fully charged state
what is the performance condition when 5Kwh of energy is left ?
B Patel,
Lithium ion batteries are capable of delivering nearly constant amps until only 10% charge is left. The voltage drops gradually as you indicate.and then drops precipitously when close to 0% charge left. The maximum possible current does drop about 20%.
Back to your original issue, the current draw is continuously variable depending on acceleration. Elon says that the battery pack can charge from 10% to 90% over 45 minutes which for a 300 mile pack (90 kWh) equals a charge rate of 96 kW.
This compares with the motor which draws 300 kW max. This only occurs during maximal acceleration.
Again the current draw ability is not dependent on the state of charge for the batteries.
By the way when talking about batteries, the c rate is 1 when a full charge is given or removed over one hour. Different batteries support different c rates without damage. For the Model S the max instantaneous discharge c will vary from about 3.5 to 6 depending on the size of the pack. Part of the damage potential is time dependent. Maximum acceleration would last 5.6 seconds if going to 60 mph. This is not all that long for batteries as demonstrated by the experience of Roadster owners.
I know some other has asked this question and it has been answered with, not needed, or more free energy nonsense.
But I do see sense on asking or...
