Front Storage Container
I apologize if this has been previously discussed, but I amn searching for a container that can sit in the well between the driver and passanger that closes. I would like something in which to keep sunglasses, change and various other items. I'm not sure it needs to have a beverage holder or anything too fancy, just wondering who mayt have also sought out and found a satisfactory solution to the lack of closed stoarage space.
Thanks all,
Louis
Please see this thread:
http://www.teslamotors.com/forum/forums/aftermarket-approach-tms-opportu...
You can also try http://volkerize.com to search the public threads of these fora, for example, for "opportunity console".
Here are a couple others some folks have used:
http://www.clava.com/small-rectangular-box.html
http://www.clava.com/cube-box.html
http://www.amazon.com/gp/product/B000XVB0QE/ref=twister_B003LU0AQ0
There are a variety of others on Amazon as well. The width of the handbag trough near the armrest is 6" and it gradually gets wider as it extends toward the front of the car.
Can't remember which thread it is in, but someone suggested the mini-tote from Michaels. It is in the bottom left picture below. I drilled the rivets out, removed the center part, and the main part fits perfectly under the cubby. I put my sunglasses, change the parking meters, pens, etc. in there. It is virtually invisible under the cubby.
Uploaded from Photo Slice
@Nickjhowe: That looks good. Do you have a link for the product? Went on Michaels and can't find it.
Hello Louis,
The best I have seen so far:
http://www.teslaccessories.com/Teslaccessories.com/Home.html
Brgds, Patrick
@Hills - was never able to find it online. It was in both Michaels stores I went in.
And it costs about $13.
@nickjhowe
You are talented, awesome, and value add to the forum. Thank you so much.
::blush::
Found the details over at TMC. See this post.
Heres the tote:
it's nuts that something isnt standard yet!
@Nick
Go to physical store? What a concept. Just came back from Michaels. Got 2 for $14. It certainly isn't high end material, but that may be a plus so not to attract break-in. Enough room for small stuff, and still leaves the center for my wife's bag when she drives the car. Happy.
Now, how did you drill the rivets out?
@Hills - yes - physical store. How old school. :-)
I have a pillar drill. It was easy to put the tote under it and just drill them out. A hand held drill would probably be just as easy. It leaves holes, but with it tucked away under the cubby you can hardly see the (horrible) paisley interior, let alone the holes. If you wanted to be really neat you could always put some press-studs into the holes.
My, you are equipped too!
I was about to hand drill, then decided just to cut the handle off. Took a marker to blacken the small portion that has cardboard exposed. Now the center has 3 compartments. Shove the caddy under the cubby, all done. Black on Black, no one needs to know it is there. Thanks.
Low tech is often the best and simplest solution!
I like the tote solution. It will allow me to quickly grab all of my junk when I want to move to another car for the day.
CCI = Cheap Console Insert? ;)
