Battery Charge Time?
Does anyone know if there is a table or chart that indicates how long the charge time is for the three battery packages (160, 230 and 300 miles) charged at a 110 volts/15 amp - wall outlet or 220/30amps - Dryer outlet? Thanks
I'm not a battery tech guy, but here's my attempt based on simple power equations. I assume:
  • 10% conversion losses
  • 90kWh battery on 300-mile battery
  • proportional battery sizes on the 230- and 160-
And here's what I get for a notional 100% Depth of Discharge recharge. Note that this is extreme!
Volt*Amp
Batterie
300mi230mi160mi
90kWh69kWh48kWh
110*15=1.65kW60.646.532.3
220*30=6.6kW15.211.68.1
If someone who has real information could post, I'm happy to yield!
RB, those appear to be very conservative numbers. (not a bad thing) You certainly wouldn't want to use 15 amps except in a pinch.
Thanks
So I can drive my 300 mile model S from Seattle to Whistler, BC (200 miles), park it in the garage charging on 110 for a couple of days and drive back home. That should work.
Yep, but I'm guessing that any of the Whistler resorts will provide some form of 220v charging at some point.
