On a full standard charge I'm getting 191 rated miles. Is that consistent with others' experience with the 60kWh? I've only got 171 miles on her so I'm relatively new to this!
That is what I get with my 60kwh. Standard is set to 80% charge to perserve battery life, so that is 184 miles. Tesla says that is the best setting if you are not needing the full 230 mi range.
I'm a Newbie 60kWh owner too and I consistently see 189 rated miles.
Mine reads 189 on a full standard charge. And I'm a newbie too, just got the car on Sunday.
185 to 190 miles is right depending on the temperature and how long the car has been sitting since the charging has finished.
I'm getting 214 miles on standard charge. I live in the NE with temps in the 20's and currently two feet of snow. I picked my 60kwh last Saturday.
Sorry just checked. I have my range indicator set for ideal range. That's probably the difference.
I'm mostly getting 189 but I've seen 190 a couple of times.
Has someone charged full range? Does it show 208 or higher?
I seem to get 189 and 217 respectively. I did a range charge once and was surprised by the numbers. It was 200 and 226. It sat on those numbers for what seemed like the last hour of the charge. Once I started driving I did notice that my mileage did not decrease for approximately 10 miles.
Hi everyone, I've learned a lot from these forums and wanted to share what I've found to take care of my model S.
Here is a picture of all the items...
